Deleted member 103408
From the Golf Manual
Traffic sign recognition texts Cause and solution
No traffic signs detected The system is in the initialisation phase.
OR: the camera has not detected any regulatory or warning signs.
Error: traffic sign recognition System fault.
Go to a qualified workshop and have the system checked.
Traffic sign recognition: clean the windscreen! The area of the windscreen in the vicinity of the camera is dirty.
Clean the windscreen.
Traffic sign recognition: currently restricted. No data transmission from the navigation unit.
Check if valid map data is loaded on the navigation unit.
OR: the vehicle is located in an area that is not covered by the map stored on the navigation unit.
No data available Traffic sign recognition is not supported in the country in which you are currently travelling.
Sounds like your error is not the same as mine (and other MIB1 Units) where the warning message appears after a fixed time regardless of where you are or what route you have taken. Are you maps up to date and does the navi system show the speed limit at the same point.
