Ronin225's Candy rimmed Black LCR - Project 500-4WD, Cage installed and bigger turbo
Ronin225
4,652
22
Worcester
Its been good so far, only had a few drives to test it as mostly i've been in the boring rush hour jams where boost is of no help
First is spot on at the moment on the damp roads though, can quickly nail it out of a junction and keep it just on the limit of traction giving me a quick start
Not had chance to scan or log it yet but feels ok, only thing i have noticed is if i give it a couple of miles of thrappage and catch traffic/stop, i can smell a horrible burningy smell which goes after a few minutes
Also i booted it the other day with a friend following and he said it stank of cat, DIY decat coming i think and hopefully this may allow the adding of timing top end too
antony-lcr
Burning smell could be the high temp boost hose off the turbo hot side. My original has a small tear which when hot expanded and leaked oil vapour near the manifold, it still held boost though :s worth a check
Ronin225
4,652
22
Worcester
I would hope that hose is ok as i replaced it with the forge fluorosilicone one a few years ago
When i get some time i'll give it a check though
Ronin225
4,652
22
Worcester
Yesterday saw the end of the S3, but what was left was worth £70:D
Helped Seal fit his FMIC too and had someone else drop a cupra tdi over for me to look at, which was easily the most neglected leon ive seen
Ronin225
4,652
22
Worcester
Tell me about it, think i may just walk away from it now instead or make a very low offer to buy
Just been and done the deal on the audi so should be here in a few days
cupra-barn
It's all about stealth!
Aug 4, 2010
2,109
Worcester
I can't believe as one audi goes the next arrives....oh well...more to tinker with ;)
Ronin225
4,652
22
Worcester
The audi is coming in as a fix up and flog on, i have a nice shed of spares to use now too
Failing its relatively cheap fix, it will be broken, even has the AGU lump
Ronin225
4,652
22
Worcester
The new mini project was picked up tonight (and for an obscenely low price too)
I'll get some other pics later in daylight and work will start on this as well as some overhauling of the LCR next weekend
steeler
help
How can i advertise my Leon Cupra R on here?
Its time to sell after 6 enjoyable years with her!
Ronin225
4,652
22
Worcester
It seems again its the time of year for everything to start breaking again
The other rear wheel bearing is now making a horrific hum, replaced the other side last october
The thermostat is stuck open so on a fast drive the temp gauge starts to drop
Add to that the return to my swimming pool car this evening, did 3 doors when resealing but ran out of time to do the 4th and forgot about it.
I've noticed majority of the water is in the passenger front footwell and wonder if when mapped and the scuttle panel was removed, the little removable piece may not be fitted and leaked through the pollen filter, so interior out tomorrow
Also my poly'd wishbones will be coming off the car in the next few weeks for something a little different
steeler
being a "newbie" i dont think im aloud to advertise it yet. cant find the SELL section anyway so im assuming thats why... this site is hard enough to negotiate as it is, let alone having that rule!
will try again with it another time. its on autotrader for now.
anyway, i had the water problem a few years back. took me ages to work out what it was. had all the door seals off and everything, but all it was was that the pollen filter had been put back in a tiny bit bent and this c0cked it all up. water seeped in and hey presto - mouldy mats.
check that first mate, make sure its all in perfect, no bent flaps etc. that should see you right.
