Another busy day! Got my induction kit fitted,
Bled the clutch
And moved the car out of the garage!
The sump is sitting mega low...
So will be raising up the engine with these
Since i got the car out the garage i prepaired to run in the engine, (see video below) started up fine, no leaks, oil light not on, started to get some smoke from the engine bay, and i was so angsty and nervous i shut it off. It turned out to be the lambda wiring melting on the downpipe
its not a nice thing doing an initial start up on your own, as you can't be everywhere at once! I will shortly be booking it in and trailering it to get my eggsauce made, so that it will be a little less asbo.I will be fitting my miltek cats, and going for a 2.75 pipe back to a hidden tail pipe.
www.youtube.com/watch?v=VbEKZSGYMvU
