Rear end off the a3 was looking scabby so Jordk offered to bead blast the parts and give them a lick of paint at his work, then two days later my mate tells me his boss is away on holiday and says he can powdercoat all my parts cheap,since I have 2 rear ends I decided I'd just get them both done, so here is a before and after of the parts he has done so far#
Some pics of the goodies for the rear end
Before I could proceed any further with
The chassis I had to make up front to rear brake pipes which I couldn't be assed doing coz 1- the rain didn't fcuk off and didn't wanna lie in the wet and 2- I had no idea how long they had to be at the rear until I get the trailing arms back on so I just flared one end of
The pipe and shaped the pipes to the rear so I could refit the petrol tank. Once The trailing arms are
Fitted I'll cut the pipe shorter and flare them on the car.
I could make straighter b/pipes with my eyes closed lol
Now that the pipes was done I could start rebuilding the car. So cracked on with the petrol tank.
This is pretty much the stage I am at right now, ordered my standalone diff controller last night from Germany £800!!!!!!! Last of the chassis parts will get powdercoated tomorrow hopefully and I've ordered new bushes and clips that I had to strip off the rear subframe to get powder coated which will also be Here tomorrow another £200!!!!!
Once I get all these bushes from seat tomorrow that's me pretty much ready to mount the diff onto the car :-D
All parts now powdercoated and cleaned
Some more parts
Well 2 parts I ordered was wrong and two bushes was on back order so these was holding me up...........but the nice manny from seat came today and delivered them
So all I need to do now Is press the bushes in, fit the disc shields, press the hubs into the bearings on the trailing arms and start building woop woop.
Might be on it's wheels this weekend if I push
Small update, started bolting the running gear back on today, managed to get the rear Diff and cradle on, then the 4 control arms and rear shocks.
Just need to get the trailing arms on now
Well progress has been slow lately.
Got the trailing arms on ready, then got the rear anti roll bar fitted too
I then started to get the rear brakes back onto the trailing arms and have ran into a snag! The caliper carriers are different from my Leon! Callipers are same as the s3 but carriers on a 4wd are different so again im waiting on parts to arrive!!!
Picked my brakes hoses up from Wallace today, but the ends are slightly bigger so I'll need to bore out the hole in the mounts for them to slide thru.
Some more progress made, finally managed to get the rear brake hoses to fit and flared the pipes to suit
I also got the last of the welding done and welded in the mounts for the propshaft and got the rear half of the prop mounted ready for the gearbox to be fitted.
The rear arch liners off the Leon no longer fit so I had to use the ones from the a3 but they was slightly different as the Leon bumper sits wider so I had to chop up the Leon arch liner and do I bit of plastic welding to make 2 liners into one around the rear bumper. Nowt fancy buy it's functional
I also got the skirts back on today but are a bit scuffed up from storage grrrrrr
Well after spending most of today on my arse staring at the rain I Thot I better go out and press on with the Leon regardless
Because I'm stuck waiting for parts for the rear end ive had to start work on the front end, first off I had to hack off my locking wheel nuts coz I Lost The key :-/
Anyway to fit the new gearbox with transfer box I Thot it would be easier if I removed the subframe and polybush everything at The same time.
Anyway subframe off
Well progress Is flying now that I'm onto the mechanical side of the build
Removed the old clutch and flywheel then fitted the lightened flywheel and fast road clutch
Well about an hour later I got the box in place and bolted up
Well as I refused to pay the price seat wanted for rear brake pipe/hose Assy and no companys seem to make them either I decided to ask if Wallace could custom make the hose with a normal female end so I could make up the pipe myself and screw it into the hose, where as the originals are a complete unit where the hose and pipe cannot be separated.
Whilst doing my clutch I noticed the feed pipe also has a rubber hose so I Thot fcuk it and dropped the original off at Wallace this morning and they made the 3 hoses for me.
Just back from picking them up so I'm away to make up the pipe to complete The rear brake lines whilst the suns out
Simple and easy, fitted the clutch hose and made up rear pipes and fitted to the hoses, just need to wait for my new carriers and the rear end is finished woop woop
New rear pipes getting made
Nowt worse than getting rudely awakened on a saturday morning! Unless of course it's the postman with presents
If anyone can make any sense of
These fitting instructions come see me lol
Bit more progress tonight, I thot I'd start installing the diff controller, plan was to wire it all up behind the stereo as thats where all the wire seem to be, plus I need to make a surround to hold the screen and the control switch, seeing as the wires between the module and the screen aint long I've decided to do away with my middle air vent and house everything behind it. Some pics of my progress.........
Finally it comes to life
Been at the car since 5 and looks like I've done next to nothing, finished up wiring the diff controller and tidyed up the loom behind the stereo as whoever installed the reverse camera and roof mounted tv just crammed all the wires behind the headunit and it annoyed me, once all the wiring was sorted I could start putting the interior back together.................all was well until I came to the rear trims and now the differences between the floors come apparent. The a3 floor is minus certain fixing points to screw the interior trim to.
So I've given up for the day as in still in pain after football last night
Ah ha the final piece of the jigsaw to finish up the rear end
Even better........more goodies arrived today
Well got the new carriers painted And went to fit the brakes to the rear, driver side went on no
problem
But for some reason the passenger side carrier fouls the disc :-/
I have a feeling that the bearing isn't pressed in 100% which is making the hub/disc sit just out of place
