Couple of answers for the questions you posted earlier.
The S3 propshaft should be fine, it's the TT ones that are shorter.....like what i have.
And the haldex is controlled via the canbus system via the abs ecu not the engine ecu.
How you planning on cutting it ? Plasma or grinder etc.
Cheers for the knowledge insert graham
Just been out and had a look with Phill at the S3 especially the ABS unit.
I assume the ECU for this is inside the unit itself??
I know a few of the the ports would need to be larger to suit the enlarged piping for the brembos.
But other than that if this unit is swapped out into a LCR is it a self regulating and controlling unit = working haldex?
I think i'm going to look at getting a plasma/tig welder as plasma cuts although rougher finishing are much more manouvreable and easier and dont remove as much material.
Then just a tickle over with a grinder to get it nice and ready for fitting
Anything else i should look at??
