Personally i think your going about this the wrong way mate, your obviously quite handy.. i've read your rebushing guides etc so you should be using this BT project to learn your car inside and out. It will save you a fortune in the end and be an amazing experience.
When you read people running BT set-ups there is always drama along the way to some extent.....
Read loads, buy Haynes manuals etc.... just research everything, Give it a go.... just take your time, Take loadsa pictures during strip down.... observe how things come apart (just think along the lines of is the part symetrical - think can it fit the wrong way round ???does it have to go back the same way round.. if so mark it up)
If you get stuck get on here and ask for advice....
Edit - Just read that back.... not trying to patronise you mate, just give you a bit of confidense to give it a go. Don't worry about the stroker kit.... it'll fit great.
One very happy Tim lol
Looking forward to do some logging sessions this evening to see what differance the green monster makes!
I may have to 'borrow' this program from you if thats ok, everything all helps
Tom i'll be going over to Barn's at about 8 but i think he's got man flu or AIDS or something so might not be up for too much logging
Thought that might get your attention, didnt manage to fit the old airbox, etc at break time so late night driveway mods it'll have to be
Group A: '003 Group B: '020
RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME
Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF
0.44 2880 91.92 98.8 18.8 0.01 0 0 0 0
1.24 3120 90.08 100 13.5 0.84 0 0 0 0
2.06 3400 100 100 18.8 1.66 0 0 0 0
2.86 3680 105.78 100 15.8 2.46 0 0 0 0
3.66 3920 114.39 99.6 19.5 3.26 0 3 3 0
4.47 4200 120.06 100 16.5 4.06 0 3 3 0
5.37 4440 130.39 100 17.3 4.97 0 2.3 2.3 0
6.28 4720 132.78 100 17.3 5.88 0 2.3 2.3 0
7.08 4960 142.28 100 16.5 6.68 0 1.5 1.5 0
7.99 5200 149.11 100 17.3 7.48 0 1.5 1.5 0
8.89 5440 162.44 100 17.3 8.49 0 1.5 1.5 0
9.89 5720 173.11 100 15 9.4 0 0.8 0.8 0
10.71 5880 182.75 100 15.8 10.29 0 0.8 0.8 0
11.61 6080 187.28 99.2 16.5 11.11 0 0 0 0
12.41 6240 187.28 99.6 18 12.01 0 0 0 0
13.22 6400 187.64 100 19.5 12.82 0 0 0 0
TIME TIME
0.41 2840 93.08 98.4 16.5 0.01 0 0 0 0
1.31 3160 87.22 100 14.3 0.91 0 1.5 0 0
2.11 3400 99.22 100 18 1.71 0 1.5 0 0
2.92 3680 105.83 100 18.8 2.52 0 0 0 0
3.72 3920 114.78 100 19.5 3.32 0 0 0 0
4.52 4200 119.06 100 19.5 4.12 0 0 0 0
5.34 4440 126.83 100 18.8 4.94 0 0 0 0
6.23 4680 132.39 100 18 5.83 0 0 0 0
7.05 4920 141.25 100 17.3 6.64 0 0 0 0
7.95 5200 151 100 16.5 7.55 0 0 0 0
8.86 5440 164.03 100 15.8 8.46 0 0 0 0
9.66 5640 172.25 100 15.8 9.26 0 0 0 0
10.46 5840 181.25 100 15.8 10.06 0 0 0 0
11.27 6040 184.83 100 15.8 10.86 0 0 0 0
12.07 6200 188.17 99.6 18 11.67 0 0 0 0
12.87 6360 185.44 98.8 18.8 12.47 0 0 0 0
13.69 6520 182.75 97.6 20.3 13.27 0 0 0 0
TIME TIME
0.36 2800 81.69 96.5 10.5 0.77 0 0 0 0
1.27 3080 87.33 100 13.5 1.67 0 0 0 0
2.18 3400 99.44 100 17.3 2.67 0 0 0 0
3.07 3680 107.14 100 18.8 3.47 0 0 0 0
3.87 3960 114.36 100 19.5 4.29 0 0 0 0
4.69 4200 118.28 100 19.5 5.09 0 0 0 0
5.59 4440 128.14 100 18.8 6 0 0 0 0
6.4 4720 132.97 100 12.8 6.9 0 0 0 0
7.3 4960 143.69 100 16.5 7.7 0 0 0 0
8.11 5200 152.08 100 16.5 8.61 0 0 0 0
9.01 5440 161.14 100 16.5 9.41 0 0 0 0
9.81 5640 171.58 100 15.8 10.22 0 0 0 0
10.63 5840 181.25 100 15.8 11.02 0 0 0 0
11.43 6040 185.75 100 15.8 11.84 0 0 0 0
12.33 6240 180.53 51 18.8 12.85 0 0 0 0
13.35 6440 175.03 51.8 19.5 13.74 0 0 0 0
TIME TIME
0.01 2720 34.25 23.1 30.8 0.4 0 0 0 0
0.81 2920 95.67 99.2 15.8 1.31 3 0 0 0
1.71 3240 91.81 100 16.5 2.11 3 0 0 0
2.52 3480 102.28 100 15 3.02 2.3 0 0 0
3.42 3800 110.75 100 19.5 3.82 2.3 0 0 0
4.22 4040 115.11 100 18.8 4.64 1.5 0 0 0
5.13 4320 125.92 100 17.3 5.53 1.5 3 0 0
5.93 4560 131.78 100 15.8 6.33 1.5 3 0 0
6.75 4800 134.31 100 17.3 7.15 0.8 2.3 0 0
7.55 5000 144.92 100 17.3 7.95 0.8 2.3 0 0
8.35 5240 157.92 100 15.8 8.86 0 1.5 0 0
9.26 5480 173.33 100 15.8 9.66 0 1.5 0 0
10.15 5720 181.25 100 15.8 10.57 0 1.5 0 0
10.97 5920 190 100 15.8 11.37 0 0.8 0 0
11.78 6120 185.42 50.2 16.5 12.18 0 0.8 0 0
12.58 6280 178.89 50.2 19.5 13.08 0 0 0 0
TIME TIME
0.01 2720 35.17 19.2 29.3 0.4 0 0 0 0
0.8 2840 86.81 94.5 20.3 1.2 0 3 0 0
1.6 3120 86.42 100 12 2.01 0 3 0 0
2.51 3440 100.5 100 18 2.91 0 2.3 0 0
3.42 3720 107.64 100 18.8 3.82 0 2.3 0 3
4.32 4000 115.39 100 20.3 4.83 0 1.5 0 3
5.23 4280 123.58 100 15.8 5.63 0 1.5 0 3
6.12 4560 132.58 100 17.3 6.52 0 1.5 0 2.3
6.94 4760 134.92 100 14.3 7.44 0 0.8 0 2.3
7.84 5040 147.19 100 15.8 8.24 0 0.8 0 1.5
8.65 5280 158.89 100 16.5 9.15 0 0 0 1.5
9.55 5520 172.83 100 12.8 9.95 0 0 0 0.8
10.46 5760 186.33 100 12.8 10.86 0 0 0 0.8
11.26 5960 193.08 100 14.3 11.66 0 0 0 0.8
12.06 6120 183.33 49.8 17.3 12.47 0 0 0 0
12.88 6320 182.44 48.2 17.3 13.27 0 0 0 0
TIME TIME
0.01 2680 55.56 28.6 24.8 0.4 0 0 0 0
0.8 2880 92.36 100 12.8 1.2 3 0 0 0
1.71 3200 89.36 100 15.8 2.11 3 0 0 0
2.51 3480 99.75 100 16.5 3.01 2.3 0 0 0
3.41 3760 109.08 100 19.5 3.82 2.3 0 0 0
4.32 4040 118.69 100 18 4.72 1.5 0 0 0
5.12 4280 124.97 99.6 18.8 5.53 1.5 0 0 0
5.93 4520 132.42 99.2 15.8 6.33 0.8 0 0 0
6.73 4760 132.39 100 17.3 7.13 0.8 0 0 0
7.53 5000 142.47 100 16.5 7.93 0.8 0 0 0
8.35 5240 155.28 100 15.8 8.85 0 0 0 0
9.24 5480 173.67 100 15.8 9.66 0 0 0 0
10.04 5680 182.75 99.6 15 10.46 0 0 0 0
10.86 5920 191.53 100 15.8 11.28 0 0 0 0
11.77 6120 184.22 51.4 17.3 12.17 0 0 0 0
12.57 6280 180.67 49.4 18.8 12.97 0 0 0 0
13.39 6440 182.75 51.4 18 13.88 0 0 0 0
TIME TIME
0.49 2760 76.39 90.6 21.8 0.01 0 0 0 0
1.31 3000 89.72 100 12 0.89 0 0 3 0
2.2 3320 96.89 100 18 1.8 0 0 3 0
3.12 3600 102.58 100 17.3 2.72 0 0 2.3 0
3.91 3840 113 100 19.5 3.52 0 0 2.3 0
4.71 4120 119.78 100 18 4.32 0 0 2.3 0
5.63 4400 126.83 100 19.5 5.13 0 0 1.5 0
6.54 4640 133.14 100 16.5 6.03 0 0 1.5 0
7.34 4880 141.44 100 16.5 6.94 0 0 0.8 0
8.14 5120 145.78 100 13.5 7.74 0 0 0.8 0
9.05 5360 163.56 100 15.8 8.65 0 0 0 0
9.95 5600 177.14 100 15 9.45 0 0 0 0
10.76 5880 189.69 100 12.8 10.36 0 0 0 0
11.66 6080 198.75 100 13.5 11.26 0 0 0 0
12.47 6240 182.75 48.6 15 12.07 0 0 0 0
13.37 6400 182.44 49 19.5 12.98 0 0 0 0
14.28 6560 178.89 51.4 21 13.78 0 0 0 0
15.08 6200 0 8.6 7.5 14.68 0 0 0 0
No individual cylinder causing any problems but the CF's arent high and mainly lower down in the rev range.
The only thing i did notice and feel was about 6k rpm it holds back, looking at the load it drops to 50ish% but foot is still flat, dont know why?
Especially as at this point i'm getting 0 CF's across the board, maybe too much air flow??
Then in a quick 5 minute change over on the side of the road swapped back to the mahoosive cone to log that, ended up doing 4 runs but what the hell
Code:Group A: '003 Group B: '020 RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME TIME Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF 0.01 2720 34.25 23.1 30.8 0.4 0 0 0 0 0.81 2920 95.67 99.2 15.8 1.31 3 0 0 0 1.71 3240 91.81 100 16.5 2.11 3 0 0 0 2.52 3480 102.28 100 15 3.02 2.3 0 0 0 3.42 3800 110.75 100 19.5 3.82 2.3 0 0 0 4.22 4040 115.11 100 18.8 4.64 1.5 0 0 0 5.13 4320 125.92 100 17.3 5.53 1.5 3 0 0 5.93 4560 131.78 100 15.8 6.33 1.5 3 0 0 6.75 4800 134.31 100 17.3 7.15 0.8 2.3 0 0 7.55 5000 144.92 100 17.3 7.95 0.8 2.3 0 0 8.35 5240 157.92 100 15.8 8.86 0 1.5 0 0 9.26 5480 173.33 100 15.8 9.66 0 1.5 0 0 10.15 5720 181.25 100 15.8 10.57 0 1.5 0 0 10.97 5920 190 100 15.8 11.37 0 0.8 0 0 11.78 6120 185.42 50.2 16.5 12.18 0 0.8 0 0 12.58 6280 178.89 50.2 19.5 13.08 0 0 0 0
Code:Group A: '003 Group B: '020 RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME TIME Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF 0.01 2720 35.17 19.2 29.3 0.4 0 0 0 0 0.8 2840 86.81 94.5 20.3 1.2 0 3 0 0 1.6 3120 86.42 100 12 2.01 0 3 0 0 2.51 3440 100.5 100 18 2.91 0 2.3 0 0 3.42 3720 107.64 100 18.8 3.82 0 2.3 0 3 4.32 4000 115.39 100 20.3 4.83 0 1.5 0 3 5.23 4280 123.58 100 15.8 5.63 0 1.5 0 3 6.12 4560 132.58 100 17.3 6.52 0 1.5 0 2.3 6.94 4760 134.92 100 14.3 7.44 0 0.8 0 2.3 7.84 5040 147.19 100 15.8 8.24 0 0.8 0 1.5 8.65 5280 158.89 100 16.5 9.15 0 0 0 1.5 9.55 5520 172.83 100 12.8 9.95 0 0 0 0.8 10.46 5760 186.33 100 12.8 10.86 0 0 0 0.8 11.26 5960 193.08 100 14.3 11.66 0 0 0 0.8 12.06 6120 183.33 49.8 17.3 12.47 0 0 0 0 12.88 6320 182.44 48.2 17.3 13.27 0 0 0 0
Code:Group A: '003 Group B: '020 RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME TIME Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF 0.01 2680 55.56 28.6 24.8 0.4 0 0 0 0 0.8 2880 92.36 100 12.8 1.2 3 0 0 0 1.71 3200 89.36 100 15.8 2.11 3 0 0 0 2.51 3480 99.75 100 16.5 3.01 2.3 0 0 0 3.41 3760 109.08 100 19.5 3.82 2.3 0 0 0 4.32 4040 118.69 100 18 4.72 1.5 0 0 0 5.12 4280 124.97 99.6 18.8 5.53 1.5 0 0 0 5.93 4520 132.42 99.2 15.8 6.33 0.8 0 0 0 6.73 4760 132.39 100 17.3 7.13 0.8 0 0 0 7.53 5000 142.47 100 16.5 7.93 0.8 0 0 0 8.35 5240 155.28 100 15.8 8.85 0 0 0 0 9.24 5480 173.67 100 15.8 9.66 0 0 0 0 10.04 5680 182.75 99.6 15 10.46 0 0 0 0 10.86 5920 191.53 100 15.8 11.28 0 0 0 0 11.77 6120 184.22 51.4 17.3 12.17 0 0 0 0 12.57 6280 180.67 49.4 18.8 12.97 0 0 0 0 13.39 6440 182.75 51.4 18 13.88 0 0 0 0
Anyway this yielded a max flow of 198.75Code:Group A: '003 Group B: '020 RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization TIME TIME Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF 0.49 2760 76.39 90.6 21.8 0.01 0 0 0 0 1.31 3000 89.72 100 12 0.89 0 0 3 0 2.2 3320 96.89 100 18 1.8 0 0 3 0 3.12 3600 102.58 100 17.3 2.72 0 0 2.3 0 3.91 3840 113 100 19.5 3.52 0 0 2.3 0 4.71 4120 119.78 100 18 4.32 0 0 2.3 0 5.63 4400 126.83 100 19.5 5.13 0 0 1.5 0 6.54 4640 133.14 100 16.5 6.03 0 0 1.5 0 7.34 4880 141.44 100 16.5 6.94 0 0 0.8 0 8.14 5120 145.78 100 13.5 7.74 0 0 0.8 0 9.05 5360 163.56 100 15.8 8.65 0 0 0 0 9.95 5600 177.14 100 15 9.45 0 0 0 0 10.76 5880 189.69 100 12.8 10.36 0 0 0 0 11.66 6080 198.75 100 13.5 11.26 0 0 0 0 12.47 6240 182.75 48.6 15 12.07 0 0 0 0 13.37 6400 182.44 49 19.5 12.98 0 0 0 0 14.28 6560 178.89 51.4 21 13.78 0 0 0 0 15.08 6200 0 8.6 7.5 14.68 0 0 0 0
This works out as an increase of 10.58g/s in cone over filter
Also the max flow works out to 248.43hp which is nice considering its still on the OE map
