Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Also the slotted ring on the crank (great technical term) Assume its for rotational speed has been a little bit damaged, not sure if this is a deliberate slot or broken bracing piece. How important is this that it has to run extremely true, is it malleable enough to manipulate back into concentricity
The box also contain quite a few of Phillc's parts but i thought i'd let him post all the pohotos of them.
Anyway just waiting on another package from INA to complete the order and it'll be time to get cracking
Trigger wheel, isuppose that sounds better than the sensor ring thingLOL
Its a 60-2 trigger wheel...
clue is -2
so long as its not been bent in transit and out of true thats what it should be
Yes mate, all balanced together so hopefully if its superficial damage it can be sorted hereLooking good, are you going to get the crank, flywheel etc balanced, if you are it should all be corrected with that.
Its Ok graham, we are all here because we need help, these sessions are just the start
nice box of stuff you have there mate.
Damm I need some extra cash![]()
Hopefully it will go relatively smooth and not too many problems, only time will tell
I'd better get friendly with someone who owns a garage too
hopefully i'm not too bad with my hands mate as i do the same job as you, believe it or noti'm going to speak to an engine builder near me as i'm going to see if i can book some time off work and do the rebuild with him (if he'll let me)
a lot of the time you can figure out the how but dont necessarily know why, which is what i'd like to learn.
Plus if i get it wrong its a huge amount of money down the drain, need a bit of a safety net
