Ronin225
4,652
22
Worcester
Are you sure that the fronts were backwards as my grooves are shown as yours are in the pic at the top
They were changed to this after about half an hour discussing it and a phone call to bill too
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Initially these were sold to me as being grooves swept towards the pads, and that's what Bill requests from his supplier. Due to issues this doesn't always come as requested.
As said, its all to do with the internal vane direction
Ronin225
4,652
22
Worcester
It was eventually worked out on vane direction but thought bill's grooves were always machined the same direction, didn't realise that some came through the system with different orientation
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Its your fault i put them on the way i did in the first place because i copied you discs orientation, ;) but yeah all the vanes where facing the front of the car and not rear as explained HERE and by Bills diagram.
jamfull
157
Good Evening
I`am interested in changing my inlet manifold on my 2003 AUQ how hard was this to do?. I did have a DIY job like the forge kit but need a bigger FMIC now as I`am going for one of bills Hybrids soon. I don`t want to buy a ready made kit as i have loads of piping and the forge map pipe already and i want to try something different.
Is yours off a LCR 210 AMK or 225BAM ? or does it not matter.
Did you put a catch can in because the existing piping is not easy to match up .
Love the car i like a bit of DIY but havent got the balls to do all the mods you have !!!!
Any Help gratley appreciated
many thanks
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Hi,
It doesn't matter which car you get the manifold from; LCR (210 or 225), TT or S3, but you also need the charge pipe and all the brackets and the map pipe from Forge, it all fits easily. I fitted the catch tank after all the one pipe work still fits with the LCR Mani.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Well i washed the car yesterday so i took an update pic.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Car looking amazing Phil.
I was hoping for a more exciting update though :p
When you name pops up I usually expect an interesting and informative read.
cupra-barn
It's all about stealth!
Aug 4, 2010
2,109
Worcester
I saw 'update' and thought WOW what's goin on!!
As it happens it looks amazing, hope the new sticker is on ;)
Ordered some bits from Dave today so I'll be over next week lol
Derekm2104
157
Just read from start to finish. Mostly just looking for a spec list. Epic thread all in. Liking the built not bought factor. Car's a credit to you.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Well seeing as i have just looked at my spec sheet and found it to be way out of date i have done another one:
Exterior.
LCR Front bumper
LC Face Lift Rear Bumper
Face Lift Skirts
Tear drop mirrors
Custom one off Projector head lights
Hids Dipped and main beam
Tinted rear lights
MK4 Golf Full aero wipers
Fabia Rear wiper
Peugeot fan washer jets
Smaller ariel
Smoked side repeaters
Full De-lock and relocated fuse
Interior.
Golf GTi Recaros
Custom centre vent Gauge holder
oil pressure gauge
oil temp gauge
boost gauge
Ibiza centre sun visor
LCR Vents
LCR hand brake cover
LCR pedals
LCR (225) Steering Wheel
LCR gater
Full Black interior trim
Cruise Control
Face lift clocks
Performance.
GT2X hybrid Turbo
Turbosmart E-Boost Electronic boost controller
Front mount
3" custom tip
Piper 2.5" middle section and back box
3" down pipe and De-Cat
pipercross air filter
Brakes.
Brembo calipers
333mm badger5 discs
308mm rear discs
LCR rear calipers
Yellow stuff pads all round
Map.
P-Torque custom map 300bhp 310lb torque
Handling.
Neuspeed 25mm Rear ARB
R32 front arb 23mm
Fully Polly bushed
034 motor sport solid front subframe rear bushes
TT front strut brace
LCR lower strut brace
Hughes engineering rear strut brace
THS engine mounts and dogbone
Weitec hicon coilovers
LCR wishbones
LCR hubs
Engine.
LCR charge pipe and inlet mani
swirl pot
Catch Tank
Twin cold air feed from fog light holes
13 row oil cooler
Quick Shift
THS Charge pipe and throttle body hose's
034 motor sport coil pack cover
Battery relocated to the boot
Wheels.
Mk5 R32 reps
15mm Spacers on the rear
10mm spacers on the front
Misc.
Number plate holder removed and custom mesh installed
TT jacking points
Head light washers (Porsche jets)
Full Kufatec wiring loom for the washers
Plans.
Full Re-Spray
Engine rebuild.
Forged rods
balanced crank
rebuilt head, ported, polished and gas flowed
Ferrara exhaust valves
new clutch and flywheel
Items removed.
Sai
N429 valve
N112
All associated pipe work
heat transfer oil cooler
Charcoal canister
