S3 Nattie
120
Ye I do Dan, think you seen mine before on ASN.
Its a far bit smaller than this one and wanted to change it to a bigger one anyway. Even though mine was smaller than that I still had a increase in air flow, this one should be even better.
Dani_b19
301
Arr, i remeber, the green cotton one. Yeah i know what you mean, i defo want one of these.
S3 Nattie
120
Jonny, do you have a link for the joiner and coupler. I take it the silicone pipe you used to extend the filter from the MAF housing is 80mm, is that right.;
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
This is interesting and will be good to see some figures.
I've just bought a dual cone Green Filter with a 45 degree alloy pipe and 80mm joiner.
I'm going to be removing my battery and having a second head light for a straighter flow for induction for the track.
The set up I'm buying is a good bit more expensive then the above but would doubt there is much flow difference.
If Jetex did a dual cone I would have gone that way as there cheaper.
The reason I want the dual cone is I'll direct this toward the front of the car and have other supplies to the sides of it from the OEM grill.
Nice one Jonnyjonjon for doing some investigation into other products, we need more people on SCN doing this.
JamJay
California Bound
This is what I wonder Willie, how much different would a dual-cone of a similar size be? As you say though, it's more expensive.
Green Twin-Cone:
O/D Bottom: 140mm
O/D Top: 100mm
Length: 200mm
http://www.green-filter.co.uk/product_info.php?cPath=622_757_758&products_id=100135
JETEX Cone:
O/D Bottom: 175mm
O/D Top: 140mm
Length: 172mm
http://www.jetex.co.uk/website/conicalfilters.php?insided=80mm
Green PowerFlow:
O/D Bottom: 140mm
O/D Top: 120mm
Length: 200mm
http://www.green-filter.co.uk/product_info.php?cPath=622_762_763&products_id=100302
or
O/D Bottom: 190mm
O/D Top: 120mm
Length: 300mm
http://www.green-filter.co.uk/product_info.php?cPath=622_762_763&products_id=100303
I really can't tell what one would be better.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
TBH I doubt there will be much difference.
It's the top one I've gone for from Bill
My car is unmapped so perhaps not the best car to test this on.
I have several logs with my BMC CDA on with various other mods.
I'll do some logs with this one and see if there is a difference.
I'm betting that fitting the extension will help things too as this will straighten the air flow before it goes through the MAF thus allowing us to remove the mesh infront of the MAF and hopefully increasing the g/s.
My car will end up mapped before next summer so will see what I end up with then too.
This Cone should do me for a long time as I won't be at crazy BHP for a long time.
The other reason I bought this was it sounded SO GOOD on my 106 GTI, but it won't sound half as good on my LCR:(
Dani_b19
301
We could do with comparing a similar size cone filter and a dual cone filter to see which flows the best.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yup, this is the sort of thing that can be done at the SCN National meet or at a local meet swapping bits and pieces between cars and logging the results.
Would be good to see what's what.
J0N
Defected!
This 'p-clip' came yesterday for me to try courtesy of john@forge.
Hopefully I'll get a permanent fixing sorted by the weekend so I can
get rid of the tie-wraps.
