Have got some stuff orderd to mod the fliter and bracket but will post when am done may improve airflow and also produce a smoother flow so watch this space
Sounds interesting.
Hopfully have orderd the right stuff the plan is to keep the maf in the tip , fit a 80mm 45 degree bend and a alloy 80mm hose joiner this should put the filter right by the wing allowing me to fix the filter to the origonal airbox mount and also less turbulent airflow on the maff , well this is what i hope will happen will post pics once stuff has arrived , have got to say mate your car looks really good keep up the good work .Sounds interesting.
but the 80mm are out of stock phil... im gonna go 70mm with a 70mm connector to take it closer to the wing.
I have started stocking these.. and have an 80mm on the shelf currently
For sure, bmc cai has been proven to be restrictive.Hi, sorry to be a bit backward but if I'm right this £46 cone filter will give me better performance then my rather expensive bmc cai, bolt off and bolt on???
