You can get those from ebay, i have just bought a 70>80mm silicon hose and a 80mm pipe for my Jetex to fit the Cupra, just search "silicon and 80mm" you will get loads to choose from.
Johnny could you run through
how to do the logs, i will run one to compare my Neuspeed against the Jetex, cheers.
Not sure if this helps Phil? I stole it off the Revo
guide I was just reading.
"MAF Output : Vag Com block 002, Column 4 or block 003, Column 2
Looking at the above data blocks values @full load should be in the region of:
1.8T K04 car 190-205 g/s
1.8T K03 car 150-170 g/s
2.0T FSI car (smaller turbo) 190-205 g/s
2.0T FSI car (larger turbo) 240-250 g/s
Bear in mind environmental conditions and modifications will have an effect on MAF
values. Hot weather will see lower values.
Either a faulty MAF giving a missleading signal or an inefficient intake tract will cause
the engine to pull back the boost and fueling values. If values showing a 10% or
greater loss in air flow are seen it would suggest a MAF
problem"
"The most efficient datalogs are those taken over longer ‘pull’ durations through the
rev range. For example; a 4th gear pull from 2000rpm to 6500rpm will give more
information than a 3rd or 2nd gear pull through the same rpm range as it will take
longer so more information is recorded. The only
problem with this is it also takes
more space to do, and at a higher terminal speed… Revo do not condone breaking
speed limits"
