andyc58
71
if i buy a jetex for a lcr will i need any other things as well or just straight fit
J0N
Defected!
Just as a temporary measure I've tie wrapped the end of the filter to the battery cover.
Not the best pics but there you go, it's actually quite solid but I intend to extend the section
after the MAF to centralize the filter and bring it closer to the wing so it'll do for now.
Right, the bits for the extention came in the week and here's the results.
The Coupler is from Forge, the joiner is off eBay and the clips were from work.
Still on tie wraps at the moment but I'll sort something more permanent next week.
I was thinking maybe a 12mm bolt through a short piece of 12mm rubber hose to go
through the OEM bracket that the tie wraps are fastened to, a bit like on the original
airbox.
J0N
Defected!
Another log, although as well as fitting the extention the main reason for the improvement is that I've had my ECU re-flashed with the latest version of C-C phase 1 as my engine was failing to reach maximum load.
I used blocks 003 and 115 because I was especially interested in Mass Air Flow and Boost.
Code:
Thursday	26	November	2009	14:18:38
1ML 906 032 A  		1.8l R4/5VT         0002
	Group A:	'003				Group B:	'115				Group C:	 Not Running
		RPM	Mass Flow	Load	Ign. Timing		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 /min	%	 mbar	 mbar	STAMP
	143.11	2520	62.83	98	18	142.7	2440	80.5	1670	1140
	143.91	2720	94.14	100	7.5	143.51	2600	132.3	2250	1550
	144.73	3040	132.72	100	1.5	144.33	2880	185.7	2330	2190
	145.74	3480	132.42	100	5.3	145.22	3240	191.7	2360	2320
	146.63	3840	151	100	8.3	146.23	3680	191.7	2390	2380
	147.54	4200	167.06	100	9.8	147.14	4040	191.7	2400	2370
	148.34	4520	175.61	100	12	147.94	4400	191.7	2380	2380
	149.14	4840	185.53	100	12.8	148.76	4720	191.7	2360	2380
	149.96	5160	195.56	100	14.3	149.54	5000	191.7	2340	2300
	150.76	5440	199.69	100	14.3	150.36	5280	191.7	2320	2230
	151.65	5720	201.36	100	15	151.25	5560	186.5	2300	2230
	152.58	5960	204.61	100	15	152.07	5840	190.2	2280	2130
	153.38	6160	205.92	100	14.3	152.97	6040	173.7	2230	2140
	154.18	6320	205.92	94.9	18	153.78	6240	174.4	2170	2090
	155	6480	208.25	98.4	17.3	154.58	6400	163.2	2130	2160
	155.78	6600	207.22	100	18.8	155.38	6560	169.9	2050	2110
	270.95	1880	36.89	85.5	15	270.44	1800	62.4	970	1180
	271.84	2040	48.19	91.8	10.5	271.44	1960	102.3	2210	1270
	272.75	2280	66.75	96.1	9.8	272.35	2160	125.6	2270	1480
	273.55	2560	92.67	100	1.5	273.15	2440	151.1	2350	1770
	274.47	2920	115.47	100	2.3	273.95	2720	190.2	2340	2260
	275.27	3240	126.11	100	3.8	274.87	3080	191.7	2330	2320
	276.07	3600	144.94	100	6.8	275.67	3440	191.7	2370	2370
	276.88	3960	162.31	100	9	276.47	3800	191.7	2390	2370
	277.78	4360	168.47	100	10.5	277.38	4200	191.7	2390	2370
	278.58	4680	178.72	100	12	278.18	4520	191.7	2390	2360
	279.49	5040	193.11	100	13.5	278.99	4840	191.7	2360	2350
	280.29	5360	199.69	100	13.5	279.89	5240	191.7	2330	2260
	281.1	5680	202.69	100	15	280.69	5520	189.5	2310	2240
	282	5960	204.61	100	12.8	281.5	5800	182.7	2280	2190
	283.01	6240	207.92	100	17.3	282.51	6080	176.7	2200	2160
	283.82	6480	209.14	100	17.3	283.41	6360	170.7	2130	2150
	284.62	6680	206.58	100	16.5	284.22	6600	167.7	2040	2120
	285.44	6840	179.78	52.5	21	285.02	6760	157.1	1950	2170
	286.34	7000	191.06	99.2	19.5	285.84	6920	137.6	1940	1850
	287.23	7120	146.5	36.1	9.8	286.74	7080	151.9	1860	1990
