RightyO the list i have so far is:
INA Connecting rods (19mm wrist Pins)
New Crank shaft Shells
New HeadGasket
New Rocker Gasket
New Spark Plug gasket
New Throttle bodie gasket
New Oil sump Gasket
New Piston rings(seals)
New Oil Filter
New Oil Pump
New Oil retainer
New Water Pump
New Timing Belt & Alternator Belt
New Timing Belt Tensioner
New oil return pipe line gasket,
New Oil and coolant union washers
New Inlet Manifold Gasket (Phenolic One)
New Ik22 spark plugs
New Water Pump (Metal Impeller)
Red Torco Engine assemble Grease
I miss anything off for the engine?
Ive Been Offered this Fully Built cylinder head and Rocker cover £50 has covered 111k miles what you reckon pics:
What would i have to change to get it back to new ...
