Good start so far mate, have you set a date when you wanna finish it all by
This mean its gunna go on a track? Oh goody someone to play with
Yeah i completly Understand..
Ive Been offered a Tig-art IHI Manifold Of beattie17 brand new for £250 Posted which aint too bad iMo..
If i got it Back purged and Cermaic Coated would that help it out?
Also How much is ceramic coating?
A EGT and AFR is defo on the cars which i knew that anyone i know i should of bought it a long time ago..
INA(sam) is doing me a Deal on SEM manifold With TB & INA Rods(19mm pins) So that is the 1st on the car then i can start building it up bit by bit....
You cannot back purge the tigart one now unless you get it cut up/remove the welds and get it rewelded with full penetration back purged welds. Its simply not worth it. It is buy cheap buy twice. Why the 19mm rods? Ibiza is 20mm
Yeah I thought that but HTC is using the JBS one and its been fine...I don't think i can argue about £250 can i?
Would Ceramic Coating Help it out...I would go with Bill ones but that money is on a SEM manifold and Rods
in ur old IHI pJ which mani did u use..
HTCs has been fine so far. Was his a Tigart made JBS one? The JBS mani on cupra matts old car has cracked with gt2871 apparently so its not just the k0x based ones that are affected it seems. It would be a wasted £250 imo as I would imagine it would just crack, especially with track use and then you would be looking at a replacement which would cost more than just a new manifold as you would most probably need to alter the dp etc aswell. At least buying direct you would get some warranty.
Bill:
Could you U2u me a Price to Map the TD? And Do you reckon could make me a Downpipe is so how much would it be and would u need my Car there...
If you could make one that goes down under the car then i can mount it up like HTC done...As it saves me gettin a trailer ect..
thanks
