DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
just leave the N75 plugged in, but run the pipes onto the MBC
N75 is awful, and MBC helps boost to come in a lot harder and holds boost better as well
Amen to that....
The MBC feels a God send...And looks like it comes in the same boost wise no ive driven it a few time...
I would'nt say Driving it hard it was laggy as it just goes and been up against a few thing with the same or more bhp...
I still think it can be improved tho..Like a tubluar manifold and get rid of the ATP one...OR wider charge pipe...
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
it will do the job better, but dont go thinking it will magically transform the performance of the gt2x because it wont.....it will just allow better control over what you currently have at the moment
Im not slating my gt2x i think its awesome...Just want to sort the spool up out as im abit out...
The EBC is far better as its the ecu that controls the solnoid not a Spring
mk216v
hmmmmmmmm, yummy cupra. I realy think I should shift my 16valver in for of those...........................
jamiebennett81
neither am I
I am merely stating a fact that an EBC wont magically transform the performance of the unit, it will help, but thats it - unit is laggy, has the same if not worse spool than a BT and lacks the punch of a BT, thats not slating it, again that's fact and vagcom shows this aspect quite clearly
I wish you all the best, but mine is being taken off soon
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Ta fella :D
Just bought a full Mandrel universal ID 63mm alloy pipe kit with coulples and 90degree bends of ebay 68quid posted
This is what i bought....Just Need to sort out the MbC pipe now
This reason im doing this as i took a wild quess and signed up to the golf mk4 forums and asked about it...And with my cooler being in the words ''Small'' they think theres a restricion somewere....As is seem Most of the Mk4 Gti lads use the Gt2x more than us ibiza lot...
As beattie and Matt_Cupra Both had Forge FMIC's And bigger pipe work..My uni cooler is half the size of the Forge one and is half the Flow rate goin of Robbie C's thread...So its worth a try....Plus id make my money back by selling my other sfs setup to someone who had a uni fmic..
Jamie: Yeah i completly know what you mean...If its in lag il just drop a cog or 2...Ive been playin with the mbc 2night turned it up 2 psi and boost is coming in sooner? odd?
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
A unexciting part came today lol
Merlin Motorsport 5mm self-sealing Bung for my MBC vac line for the custom charge pipe with 63m ID mandrel bends im doing...
Nice one rob for showing us this :D
Just waiting on Post now...AGAIN!
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Code:
	Group A:	'002				Group B:	'020
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF
	0.01	2320	9	1.23	4.19	0.38	0	0	0	0
	0.89	2440	57.9	6.97	28.75	1.29	7.5	4.5	6.8	6
	1.69	2600	63.2	6.56	32.61	2.09	6	3	4.5	4.5
	2.59	2800	69.2	7.38	38.5	3.01	6	3	3.8	4.5
	3.5	3040	85	9.43	53.06	4	6	3	1.5	4.5
	4.49	3400	114.3	14.35	81.06	4.89	6	3	0.8	3
	5.29	3800	136.8	18.45	103.94	5.81	5.3	6	3	5.3
	6.21	4280	157.1	21.73	130.83	6.61	5.3	6	6	7.5
	7.01	4680	157.1	22.55	140.28	7.39	7.5	6	6	9.8
	7.79	5040	151.1	22.14	145.03	8.19	7.5	10.5	9	9.8
	8.6	5320	145.9	21.73	150.11	8.99	7.5	10.5	9	9.8
	9.39	5640	138.3	20.5	150.72	9.79	7.5	10.5	9	12
	10.19	5840	136.1	20.09	152.22	10.59	7.5	10.5	9	12
	10.99	6080	132.3	19.68	153.92	11.39	7.5	10.5	9	12
Code:
	Group A:	'115				Group B:	'118
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
	0.01	2760	39.8	970	1070	0.4	2800	15	0	1080
	0.8	2880	63.2	1070	1190	1.2	2960	15	1.2	1270
	1.6	3080	79.7	1440	1360	2	3200	14	52.2	1520
	2.4	3360	105.3	1910	1720	2.8	3560	14	95.3	1930
	3.2	3760	127.8	2180	2130	3.6	3960	14	95.3	2310
	4	4160	155.6	2340	2460	4.4	4400	15	84.7	2530
	4.8	4600	158.6	2300	2520	5.2	4800	17	78.4	2500
	5.6	4960	154.9	2250	2470	6	5120	18	76.5	2410
	6.4	5280	148.9	2210	2370	6.89	5480	21	72.2	2350
	7.29	5600	140.6	2180	2330	7.81	5760	23	69.8	2290
	8.21	5920	134.6	2150	2250	8.61	6000	24	68.2	2240
Something can't be right with cf's of 12, when your not even taking it to the red line :shrug:
Does the car feel like its holding back?
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah you can defo feel it topend....you really can!!
But when i was messing around i was hittin 24psi(1.7bar) in WOT in 4th!!!!!
So the mbc tomorrow is getting turned right down to 20psi(1.4bar)...i ''MUST NOT'' of adjusted it enough when i fixed my boost leak!!!!!!!
jesus!
edit: also by looking at the logs is my FMIC doing ok?
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Well its a cold night tonight up here anyways, but its at 24 degrees at 6000 so it could be cooler really. Best thing is to get the new charge pipe on and do a full log to redline and see what temps you get then really and go from there
But like i said mine was running high cf's with the laguna, got the AM cooler and pipework on and they dropped right down, but they were neve as high as 12!
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah i completly understand!!!!
But i am wayyyy over boost in 4th what boost am i hitting and holding in them logs..
Now ive got vagcom and lemmiwinks i can sort and keep an eye on this now
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
ian_cupra
need to remove about 1 bar from what it says on vagcom, so 1.25 bar
