where do you plumb your catch tank into
Deleted member 9043
guys just to be sure becouse i dont understand everything(dutch)
-you got 1 hose from oil filter housing
-one from valve on the tip next to dv
-one connection from underside of tip?
-one vac. connection under side of the intake mani?
so first remove this all?,
than attach one hose from the tip to the catch tank?
and one hose from the other side of the catch tank to the connection above the oil filter?
and the inside of the hoses must be 19 mm ?
and blank the piece on the tip+mani of?
thanks in advance!
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
all yes but you didnt say about the rocker cover breather. this tee's into the pipe from the crankcase beather to tank. also you dont have to connect it to the tip if you dont want. just run its own filter
Deleted member 9043
ok so blank off the 2 pipes from the tip,
and one from the rocker cover to the catch tank and one from oil filter housing to the tank?
h17och
Sep 1, 2005
3,504
Dunstabubble
put the 2 pipes from the rocker cover and oil filter housing together on one of the catch tank inlets and a breather filter on the others. block all other pipes off
h17och
Sep 1, 2005
3,504
Dunstabubble
no , one from rocker cover one from oil housing
as i said ...... put the 2 pipes from the rocker cover and oil filter housing together on one of the catch tank inlets
Deleted member 9043
ok clear !
rudolf2
:cry:Just fitted mine but now the engine is running very lumpy, on idle its jumping around and not revving smoothly.
I removed MAF, N75 and the Inlet manifold to get to everything. When removing the manifold abit of debri went into the head ports could this be causing these symtoms or is maybe my MAF knackered?
Help would be appreciated
rudolf2
i did disconect the carbon canister but refitted it, checked all pipes couldnt find a boost leak. Can the MAF cause it to run lumpy? Thanks
bigboost
inlet gasket leaking, iv had it often when removeing the inlet, or an open pipe somewhere,,, possibly
Deleted member 9043
is it true that the oil pressure can change after removing the pcv valve?
