Topping up coolant - 2017 Leon Cupra 300
QTom
77
16
Well, car is at VW dealer right now, they confirmed it's the thermostat housing/coolant pump leaking which needs to be replaced, £1400 :confused:
They also pointed out some heat spots on my front brake rotors, which they recommended replacing the rotors and pads, for £820, that is a lot for 2 brake pads and discs right? Rears possibly also need doing.
Think I will bite the bullet on the coolant pump, also needs front diff oil and brake fluid done which is about £270 between them but that's not too bad and they were last done 3.5 years ago. The brakes I will leave and maybe get done somewhere cheaper (or maybe even brave doing them myself).
So I'm looking at about £220 for the service + £1400 + £270 so about £1900 all in.
Not fun but I suppose it's not too bad considering I've had the car for 4.5 years now and this is the first real expense other than normal services etc. Cheaper than leasing at least :cry:
Kind of annoying to hear about how common this coolant pump leak is though, I've found a lot of people having the same issue online (and my friend had the same thing on his S3), there was even a class action in the US and they ended up offering an extended warranty on it for 8 years there, but no such luck here as far as I know.
RUM4MO
8,030
1,094
South Scotland
I go as far to say that on going issues with VW Group products, like this thermostat-water pump plastic housing is a lot worse than annoying, it is shameful!
DEAN0
Old Git
Feb 1, 2006
5,411
Preston - UK
I would take it to an independent vw specialist - appx £700 for water pump / t stat housing.
£820 is extortionate for just the front discs & pads. ( I did all 4 corners with MTEC discs and brembo HP2000 pads for just over £500 )
The stealers would get the bare minimum work to retain any sort of warranty but nothing else.
Reactions: Mo_86
