all yes but you didnt say about the rocker cover breather. this tee's into the pipe from the crankcase beather to tank. also you dont have to connect it to the tip if you dont want. just run its own filter
put the 2 pipes from the rocker cover and oil filter housing together on one of the catch tank inlets and a breather filter on the others. block all other pipes off
Just fitted mine but now the engine is running very lumpy, on idle its jumping around and not revving smoothly.
I removed MAF, N75 and the Inlet manifold to get to everything. When removing the manifold abit of debri went into the head ports could this be causing these symtoms or is maybe my MAF knackered?
