where do you plumb your catch tank into
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
I used a 15mm tank, then sleeved the connections with the hose they supplied. Took it up to a perfect fit. :D[/QUOTE]
thats what i did.you need 19mm hose ie 3/4"
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
The second one looks better and ive used that seller before but the top one looks easier to empty
I just empty mine by disconnecting the sight tube at the top, pointing it downwards and draining into a small plastic container. The sight tube is just in push-fit fittings. I occasionally remove the tube and wash it out. This save the hassle of disconnecting the tank. :)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Sorry to bring this thread up, Im sure there be more questions once i get started next weekend :D
I`ve just orderd my catch tank (monster modz) and was just woundering how much superflex hose im going to need? Is a mtr enough?
Will i need to get any T bits or joiners etc....?
Cheers.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Bump:shrug:
Would a 1 metre be enough? as its pretty expensive and i dont want to end up with a load left if i can get away with a metre.
Cheers.
