To be honest there really isn't anything wrong with the current setup.
Nope the standard bulbs are good, but I was trying to match my led sidelights a bit better! The bulbs I currently have in look better if you're looking at the headlight but the light output is no where near as good.
Oh I have my fogs come on during the day. They have 5000k HiDs in them. When it gets dark my main beams turn on and fogs turn off automatically. The fogs match the OEM xenons pretty closely.
It's simple guys..
HiDs in normal headlight housings are unfocused, lots if glare and blind other road users. Those are the facts and it's the HiDs. Not the adjustments as you can't adjust it in a normal headlight housing. It's the reflective housing that causes this.
In a projector housing HiDs are better and more focused.
Sorry bud but that's not true. Like I said I've had cars in the past with aftermarket hids and I never blinded anyone. They even passed an mot no bother. When I fitted them you can still see the line of the beam and that was in normal headlights.
I'm going to have to disagree with you bud. I have had a car with aftermarket HiDs in them. The light pattern is all over the place. Do me a favor, pull up to a wall or garage and take a photo of the light pattern on the wall and upload it here. I will then do the same with my car ( it has OEM factory xenons in a projector housing ) and you will see the light pattern will be very different and much more focus. To make it fair park around 2m away from the wall / garage.
Of course if you prove me wrong I'll gladly accept and apologize.
Not really. The higher output of light from the HiDs will cause a lot of glare which will show in the light pattern on the wall in a reflector housing.
You could do a compare between normal and hid and you would see HiDs as brighter. Which is their purpose in life. We are looking at light pattern / glare here. Not brightness.
quite interested in this actually. i recently changed my side lights to led bulbs and have a lovely crisp white light which is massively noticable between the light colours now. id like to whiten up my front lights to match. im happy to help in any way with tests.
Reflectors have a different pattern to projectors as the projectors have a piece of metal cutting off the beam pattern. Now there are no problems with putting in HIDs to a reflector but as Tander says the 'crispness' of the cut off line is not the same. If you want brighter lights then install HIDs into your reflectors, if you want to reduce the dazzle then install the H7R bulbs however the best option are either OEM projector headlights or retrofit projectors into a set of headlights.
This I agree with. H7R bulbs would work better than normal HIDs in reflective housings. Also, OEM projectors, obviously would be the best.
I wish I could mate but I have a car with the proper xenons now lol. Its was my last that had the aftermarket ones. When I fitted them I done exactly that tho and lined them up on my fence. You could clearly see the beam pattern. Wish I took a pic now.
Fitted my Revo induction kit, didn't all go too smooth. The heat shield / barrier where the cone connects to the pipework was rubbing and didn't fit. Have to modify the heat shield to make if fit properly . Sound is pretty loud but was expected going from stock to open cone filter. While the engine cover was off I checked the DV to see that its Rev D, so no need to make expenses there.
I've just bought a revo induction kit, hope my heatshield fits and doesn't rub :(
Can you PM me some details n possibly a pic about this bud? :)
[M]ike;4337479 said:
Sure thing mate. Still need to modify and fit the heatshield. Fitting it Saturday.
Brill, thanks mate! That would be spot on!
Going to be doing mine in 2 weeks time when I return home so a few tips would be ideal along with pics and any mods that need to be done, should hopefully speed the process up for me. Cheers again :)
Fitted a pair of Osram Nightbreakers plus, which are pretty decent (till i get projector HiD's) also bumped into another forum member, Raced a 63 plate golf GTD 170 (there was nothing in it, in fact id say i was pulling better) also raced a 13 plate VXR corsa with a full Remus exhaust pushing about 210bhp, not even a car length in it (his rear bumper didnt make it past my front :) not bad for a FR TDi 170 (standard)
So these last few days I noticed my Polar FIS+ was not showing a few menu items that were there before (Rain sensor / Light sensor %, etc) unplugged it re plugged it in and reset it now it shows up. Has anyone else had this before?
dunno about that but i have noticed on mine that sometimes when im driving the display that shows you what geat your in will disappear. and then when you change gear its back again.
