Heheh
Smee- Yeah I vinyled my original before I did the Cupra R conversion. It held okay just make sure you fold it all around the edges by quite a margin so that it cant start to peel back. Its smooth on the inside so it sticks a lot better, so if you keep it taught you wont have a
problem on the front of it.
Oh and make sure you dont stretch it too much and keep the plastic hot, NOT the vinyl.
Also: I took my insert off and put it back on again probably about 7 times too, so you wont need a new one as it goes in perfectly again once it comes out as its only clipped in. The trick to it ( I found) is to push the clips out from behind and dont be scared to pull it quite hard. Its when you do it slowly and bend/stretch the clips that it could be a
problem. I also used the saw to chop every other clip off after the first time, it makes it a LOT easier to remove but it still clips in nicely, so that might be something you could try although dont blame me if you **** it up
