Mike_IbizaCupra said:You said you might come up tomorrow?
You finish at 5... no way you'll be here by 6?
Mike
Mike_IbizaCupra said:Oh right, like that is it
haha
Good ole Greg!
Mike
Ryan cupra said:Hey sorry for the late reply! my car was doing exactly the same as yours alex. and it gradually got worse as time went on until it was undrivable. i plugged vag com in a few times and was getting all sorts of faults come up, anything from Throttle Control Valve malfunction to ABS sensor and Lambda sensor fault! change everything i could and still had the same problems. I'll pm you the name of the place i used to sort my ECU!![]()
Ryan cupra said:I took it apart and saw that the main circuit board was corroded!
The engine management light, Traction control light and EPS light kept coming on and it was putting itself into limp mode. then it wouldnt idle properly and was undrivable.
It had been getting gradually worse over a few weeks. and now ive got it back i can realise how much it was under performing prior to this.
I wasnt sure if it could be done, but they downloaded my mapping then ordered the new parts and rebuilt the ecu. then uploaded the mapping again. was scared i was going to lose my Revo but they saved it!
Ryan cupra said:kind of made sence! lol.
yeh it was definatly holding back all through the revs, i thought it was just the heat but it was juddery and idled lumpy. towards the end it wouldnt rev above 2000rpm. Was using loads more petrol than it is now aswell. the ecu was just sending all the wrong signals and messing everything up!
Ryan cupra said:I reckon its a poor design of where the ECU is placed. Right under the scuttle pannel getting covered in water everytime it rains or i wash it! just got damp and corroded. think it may have been going for quite a while gradually, like maybe years. I'm going to try and rig up some sort of sheild for it to try and stop it happening again.
Ryan cupra said:Its under the scuttle pannel on the drivers side!
I know its so important and its almost as if they just couldnt be bothered to find anywhere decent to put it. lol. havent decided how i'm waterproof it yet! i think just putting a better cover over it will help quite abit. because as alex said the plastic cover that is there doesnt really achieve much!
Ryan cupra said:Yeh definatly, i will bare this in mind when making a cover for it!
Any luck with the car yet?
