Phillips1795
VCDS - How To Guides - MK3 Leon 5F
stu_m
629
52
Hull
www.themotorbikeforum.co.uk
Is the vcds hex-usb can working properly on MY16 & 17 Leons?
I read on the Gendan rosstech sites that due to change to the MQB platform some components dont work properly, just want to know which if any are not accesible.
I think It's more to do with the fact that support will be stopping for the old hex can and the new one getting more support and updates!
Dgb87
Random auto light activation
The car is also comparing the 'front' light to the 'back' light so that's why it happens.
Usually the front and rear light sensors that are located in the rear view mirror are for the dimmer rear mirror. If the rear sensor sees more light than the front then the mirror is dimmed. The auto lights and wipers work from the rain/light sensor in the windscreen in front of the mirror not the 2 sensors in the mirror itself.
I thought maybe this is some sort of random coding that put the lights on a certain time?
Garreh
28
Wolverhampton
Right had a look today, I think you might be on the wrong line.
I'm using VCDS 17.1.3, I had to scroll down just before the halfway point in the '09 Cent Elect, UDS Adaptations' to a line,-
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus
You may not have the IDE number at the start of the line if you are using earlier VCDS.
I found the line by looking at the descriptions rather than a search.
Beware there may be other lines with very similar wording!
Just a quick update - After all the issues I've been facing with this, I got hold of another VCDS cable and now everything is fine :)
Bengal
136
On vcds 17 it's all in English for the adaptations do I just take the literal interpretation?
Bengal
136
Trying to do the one press mirror fold but there is no access control 2 to choose from in central convenience only production access control which doesn't give any sub menus.
Any ideas?
Walone
1,679
489
Near Heathrow
i got one off ebay it works on my parents VW Tiguan 2012
but on my leon 2016 1.6tdi im getting errors like this....
Address 01: Engine (2D2D2-CXXB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2506
Revision: 22004001
Coding: 01114012432519090000
Shop #: WSC 00049 770 00125
ASAM Dataset: EV_ECM61TDI03004L906056CL 002006
ROD: N/A
VCID: 79FE21C6F8B54F89AE-802C
No ASAM data for: "EV_ECM61TDI03004L906056CL" (SE37)
1 Fault Found
25126 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 23461 km
Any ideas?
Has your car had the 'VW emissions' modification?
If it has then this is the probable cause.
Walone
1,679
489
Near Heathrow
Any ideas?
I think you are looking at the wrong controller, have a look at my previous posts, numbers 622, 626 and 633.
Bengal
136
Its your guides im following using VCDS 17.1.3 on my xcellence
Choose (22) Access Control , Access Control 2 Radio or IDE08542-ENG116665-Access control 2 are not present.
Using search for "Access" only "Production Access - Global" comes up and nothing for "Spiegelanklappung" :confused which is whats really strange as id expect something to come up for that.
Will try and give it a good dig later as it can only be a scan error as there are options for the mirror in general.
Bengal
136
I take it back im such a dumbass forgot to put in the security code before doing adaptation, now it magically appears!
Thnaks Walone :)
Walone
1,679
489
Near Heathrow
I would suggest doing a Full Auto scan to make sure all the control modules are recognised with no errors, if this shows ok then go to select Control modules, Select 09 (Central Elect),
Make sure 09 is Central Electronic on your vehicle.
Select 16 (Authorization), Enter Unlock Code 31347, Select 10 (Adaptation), - may be UDS Adaptations.
Then scroll down to a line 'IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,
Do not use the search function.
Just seen your new post!
Bengal
136
Yeah I found it thanks forgot to put in security code originally which is why it never appeared, thanks for your help:)
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
I keep getting code accepted when doing long coding but when i press do it and come off
Go on to check and its not changed the code
I only want sweeping needles lol
Bengal
136
Have you restarted the start/stop or ignition after doing it.
Mine only worked after i left it a couple minutes then pressed start.
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
It doesn't read unless the lights are on the dash from that point i have tried removing the key but not tried doing it with start/stop turned off i will try this and get back to you
Any more thoughts if that doesn't work ?
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
Is this something that all codeing need doing the adaptions before hand ?
Can not seem to get any other to work and can not sus out what adaption wants turning on if thats the case
Am totaly new to this
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
Omg its never ending
Vcds tells me there an update for the program so i do it like anyone would but not it can not find interface
Found driver and usb libary but no interface is that the car it can not find ?
