Check that is at least 15.x.x
Mine is 15.7.0 and works on my feb 2016 mk3
VAG Familia
Is the vcds hex-usb can working properly on MY16 & 17 Leons?
I read on the Gendan rosstech sites that due to change to the MQB platform some components dont work properly, just want to know which if any are not accesible.
The car is also comparing the 'front' light to the 'back' light so that's why it happens.
Right had a look today, I think you might be on the wrong line.
I'm using VCDS 17.1.3, I had to scroll down just before the halfway point in the '09 Cent Elect, UDS Adaptations' to a line,-
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus
You may not have the IDE number at the start of the line if you are using earlier VCDS.
I found the line by looking at the descriptions rather than a search.
Beware there may be other lines with very similar wording!
Just a quick update - After all the issues I've been facing with this, I got hold of another VCDS cable and now everything is fine
i got one off ebay it works on my parents VW Tiguan 2012
but on my leon 2016 1.6tdi im getting errors like this....
Address 01: Engine (2D2D2-CXXB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2506
Revision: 22004001
Coding: 01114012432519090000
Shop #: WSC 00049 770 00125
ASAM Dataset: EV_ECM61TDI03004L906056CL 002006
ROD: N/A
VCID: 79FE21C6F8B54F89AE-802C
No ASAM data for: "EV_ECM61TDI03004L906056CL" (SE37)
1 Fault Found
25126 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 23461 km
Any ideas?
Trying to do the one press mirror fold but there is no access control 2 to choose from in central convenience only production access control which doesn't give any sub menus.
Any ideas?
I think you are looking at the wrong controller, have a look at my previous posts, numbers 622, 626 and 633.
Its your guides im following using VCDS 17.1.3 on my xcellence
Choose (22) Access Control , Access Control 2 Radio or IDE08542-ENG116665-Access control 2 are not present.
Using search for "Access" only "Production Access - Global" comes up and nothing for "Spiegelanklappung" :confused which is whats really strange as id expect something to come up for that.
Will try and give it a good dig later as it can only be a scan error as there are options for the mirror in general.
I would suggest doing a Full Auto scan to make sure all the control modules are recognised with no errors, if this shows ok then go to select Control modules, Select 09 (Central Elect),
Make sure 09 is Central Electronic on your vehicle.
Select 16 (Authorization), Enter Unlock Code 31347, Select 10 (Adaptation), - may be UDS Adaptations.
Then scroll down to a line 'IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,
Do not use the search function.
Just seen your new post!
I keep getting code accepted when doing long coding but when i press do it and come off
Go on to check and its not changed the code
I only want sweeping needles lol
Have you restarted the start/stop or ignition after doing it.
Mine only worked after i left it a couple minutes then pressed start.
