Things I have discovered about the car.
Kieran94
47
9
is there a shortcut to switch between comfort/sport if you don’t have the steering wheel cupra button?
my Audi had auto/comfort/sport etc so all I had to do was switch the gear select lever down to sport when needed. Thanks
Deleted member 131219
may Audi had auto so all I had to do was switch the gear select lever down to sport when needed. Thanks
If you pull the gear selector back towards you, that should switch the gear box from D to S mode.
AndyCupra93
296
127
Pulling the gear lever back only changes the gear box between Drive and Sport. This is separate to drive profiles which include adaptive dampers, sound, steering etc. that can only be done through the infotainment screen without the satellite button on the steering wheel.
Reactions: Kieran94
Kieran94
47
9
A bit annoying but just what I thought, thanks though.
Kieran94
47
9
So it took me 10 mins to realise but may take others longer. Someone posted this photo on here below..and I couldn’t see the central locking/tyres options when I checked on my screen (picture 2)
as you can see on my screen below, only two are visible but you can swipe across which rotates the car and gives you the other options (the dots under the front wheel).
CupraNewboy
123
78
It's just ventilation and it won't do much, at least when it's cold. I was hoping it will help with defrosting windscreen, but absolutely no difference. You don't need any special authorisation to run ventilation function.
I suppose that the ventilation going on in a hot country like Spain could make quite a difference, but agreed, it's a complete waste in colder climates.
AndyCupra93
296
127
Hi mate, I sent you a message a while ago regarding this but seems like you’ve answered it just now - activating at the dealer didn’t give you any extra temperature controls (you don’t need the dealer to allow ventilation function).
Just curious whether activating at dealer does anything other than allow remote lock/unlock (that’s the only feature on my app which asks for it)…
jcbmally
Dec 26, 2013
1,279
553
Cybertron
I suppose it’s what the user wants from it that’s important. Mixed reviews as always but I like it, for me the ability to check;
Remote lock, where parked, send addresses to satnav, highlights faults, mpg comparison, vehicle status (windows open), service info. Oh and sound horn to put the whoolies up the Mrs lol.
You have to have privacy at minimum in the car for it to work.
Only real disappointment with the app is you can’t close windows from it, you could on the Audi when I had it.
AndyCupra93
296
127
All of those mentioned, apart from remote lock, don’t require dealer activation. That’s what I was curious about - if there were any hidden features other than remote lock that require dealer activation.
Reactions: jcbmally
Cupradev
169
100
Changing the interior LED background lighting setting to drive profile/Cupra makes the LED strip on the dash glow red with throttle response ;)
Hi mate. What do you mean? I’ve tried this and mine is just a solid red LED, no difference when throttle is applied. Does yours pulse or gain intensity when the throttle is pressed?
irfy8
164
29
My leon do no light when the car is stop light glow with the throttle.
masher69
41
Northamptonshire
It almost acts like a rev counter with the light growing from the centre of the dash out and around as you apply throttle.
