Team GTR - Leon Cupra R
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Just ran a scan with VAG-COM and the following errors have come up:
VCDS-Lite Version: Release 1.1
Sunday, 19 June 2011, 13:23:22:38647
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01,02,03,08,15,17,19,22,35,36,37,46,56
Address 01: Engine Labels: Redir Fail!
Controller: 1ML 906 032 A
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 66565
VCID: 3FF156082E73
VSSZZZ1MZ5R070305 SEZ7Z0E2876670
1 Fault Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-00 - -
Readiness: 0000 0000
Address 08: Auto HVAC Labels: Redir Fail!
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC
VCID: 243BF964A7D5
Note: Excessive Comm Errors
Address 17: Instruments Labels: Redir Fail!
Controller: 1M0 920 922 F
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 04424
Shop #: WSC 00000
VCID: 2C2B1144CF05
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0934534A3AD
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 06402
VCID: 3A07271C3551
1 Fault Found:
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
End --------------------------------------------------------------------------------------------------
Trying to understand what each one means exactly in order for me to find an appropriate fix. Any insight would be highly appreciated :)
8bit
3,401
Aberdeen
I'd ring the place you got your remap, they may want to check it out. (Edit - that's probably why the car is going into limp mode.)
The others look to me like a possible grounding issue or battery issue, altho some folks have reported funny errors after mapping which don't come back when cleared. Try clearing all codes and scan again in a day or two.
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Thanks for the input guys, I now have some logs as well so going to mail it over to AmD to get their take on it. Car seems to be boosting again but errors are still there. Could be a string of things, such as DV sticking, N75 valve or connection to the valve, actuator sticking, plus other possibilities from what I have gathered whilst reading through sites
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Yeah, get it emailed over to them or PM Ben on here.
My bet is N75. They seem to be all the rage for failing at the moment, lol.
Hope you get it sorted soon as poss mate.
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Got a response today from the retailer where I purchased the downpipe and decat and they are saying its been jig checked and that they both fit ok. Some mumbling about when fit the we shouldn't had tightened any of the bolts until all the system was fitted as the flange has slotted holes giving you adjustment to rotate but from what I remember the guys never as it was so off. Not sure what to do, fight it out with them or not. They obviously not going to listen as they think they are a big brand and have final say. Bit ticked off as you can imagine
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Yeah it is mate. I'm not slating them down in anyway, I know they know their stuff etc but something obviously gone horribly wrong here. Purchased through roadrunner motorsport
D.K
LCR 225
Oct 24, 2007
6,408
se london
Might be worth haveing a word with Milltek.
I'm planing on going to Inters at the weekend so I'll be seeing the guy's from Milltek, If you drop it round I could show them and ask what they think.
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Yeah going to ring them direct to speak to them first. Il see how I get on and if still im not convinced i probably pop it over mate. Thanks for that mate, appreciate it
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Went down to AmD to get the car checked. It's been hitting limp mode every now and again and also had a few errors being reported when I last ran VAGCOM on the car.
Guys did a hours worth of checking and it seems the car was hitting the boost limit on part throttle. This was down to the MBC as they totally uninstalled it and all is running fine. I installed the MBC to run inline with the N75 valve but obviously was interfering too much.
Have to admit the car feels different now or it might be in my head. Car felt like it pulled more aggressively before although the guys are saying its pulling better now without it. Will see how the car does in the next few days and run some logs over the weekend. All in all im very happy with the service today from the guys. They spent the time to investigate and not charge me which was a touch
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Don't you just love it when you run a scan on VAGCOM and find no errors :) yes I know I am a geek!!
I do have a slightly annoying noise however. Whenever I go to hit full boost I hear a beep, sounds electrical as opposed to mechanical but then it's difficult to hear it thanks to the loudness of the car
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Ok I think I know what that noise is. Sounded more like a boost leak today and I can't find any info on these cars making electrical noises without any lights coming on. Always interesting trying to find a leak!
Also today the Team GTR lot decided that we will be heading to Ultimate Street Car again this year. Will most likely get a stand like last year which was cool. Means I have a few weeks to find this leak and do my usual checks on the car :)
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Not much of an exciting update, but been doing the usual checks on the car and sorting any possible issues out for the trip to Santa Pod next weekend for Ultimate Street Car. Should be a good show and can't wait to get the car back on the drag. Should be able to beat my previous best of 14.8 when the car was still running standard map!!
Quick pic on how the cars looking at the moment. I raised the front ever so slightly last week, spot on for me now.
Love how the cars running at the moment both with straight line performance and going round turns. Had a nice tussle with a E46 M3 and he was shocked with how the LCR was pulling away from him. Its only then when you realize how different the car is from standard :D
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
So so glad I'm getting my wheel refurb done El, our cars look very similar!
Have a good one at Santa Pod!
Looks good mate :D
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Looks good mate :D
I know mate very similar indeed, not a bad thing tho ;) I'm still struggling to decide on what route to take my wheels. Either a refurb or a change of wheels. Need to decide very soon tho!!
Thanks mate, should be fun. Got to love a bit of racing ;)
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Defo not a bad thing matey :)
If your thinking replacement wheels, which one's? I'm sure you'll make the best decision possible bud.
I would like a set of BBS' for mine, but it's just too much money to throw at the car now when there's so much more to be done yet.
Can't beat a legal blast!
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
BBS wheels are one of the options, I know they have been done a fair amount but they do look sweet. Also looking a few other designs, bit more unique to the Leon but will see what I end up doing. I do love the standard wheels but at times do fancy a change
Legal blast indeed. Had another earlier today with my mates Subaru STI and he was loving it. Neck and neck all the way. That's impressive seen as it has the 2.5 litre high torque block
tyrer
OEM
Jun 6, 2010
1,991
Dare I say the word - replica?
We live in a throw away society and I couldn't justify £900 on a set of wheels (no tyres) when I won't have the car long enough or have the same set up on the next car to use the fitment.
I would like either Staggered CH's, Subaru PP7's/Inovit Redlines or Comp Mo 18's.
It's hard when not alot of wheels suit the LCR shape!
