got the front subframe in place yesterday. and also a Friend came over to
help me to pair the propshaft togheter again, that was not a fun job and very greasy... haha
Here it will be welded the center bearing supports to the propshaft..
Before welding i sat inside with a bootle with water and fire extinghiser.
But all went well and One side welded..
Some zinc after that Primer. then i put body sealant över that araound them
today put suspension front and back refill all oils. Engine, antifreeze, gearbox, transferbox, Rear diff, Haldex and then brakefluid, adjust all wheel angles etc..
Also connect WG and maybe my Turbosmart Eboost2 Street.
Just need to find out where i can find connections i need.
That should be it for startupp and testrun.
Getting close.
