Seat Leon Cupra Widebody AWD Built Engine, Now Interior + Further tuning of engine !
mYGeL
Cupra Widebody
Yeah. Will let you know.
Just do your best to get to GTi. If not, then maybe next year.
Thanks :) Yes will do my best just hard right now as im betveen jobs.. but soon solved :)
Great finish to the ceramic coating, looks awesome!!!
The inlet manifold looks massive!!!
Thanks :) Will get new pics upp on it :)
Didn't realise how similar the 2.0TFSI looks to the 1.8 20VT.
Loving this thread though, awesome. Best of luck with getting it done.
I think vag has used same block?
Thanks :D
mYGeL
Cupra Widebody
Well as usuall it is delayed some days. but now it atleast starts to being fun again when bolting upp parts not just cutting and welding :)
some pics.
Time for some Haldex wiring...
Now i only need to figure out where to connect the 3 wires from the extra fuelsender in the tank..
Mounting the Exhaust temp in manifold.
time to mount the manifold and turbo..
Gearbox back on car. It was very tight to get it there when turbo etc was mounted and i was alone also.. Back hurts little today.. :p
also got the rear brake pipe mounted or welded 2 brackets with the holder for brakeline on each side as i forgot to order the ones for the subframe but think this will work as good. just need to paint them today before screewing them on the car.
Also need to attach the support brackets for propshaft center bearing. and mount front subframe and so refill all oils everywhere then start upp and test drive :)
mYGeL
Cupra Widebody
Holy crap! What a car you have built!:D Subscribed!
Sent from my HTC Desire HD A9191 using Tapatalk
Thanks :D
:-o That turbo is mahoosive
Well atleast little bigger than the old K04 ;)
Thought about re-routing your gear linkage cables through your bulk head, similar to what I've just done? Check my thread http://seatcupra.net/forums/showthread.php?t=333596&page=12 Post #230 onwards.
Might give you a little more clearance :)
Looking awesome though :thumbup:
Thanks for the tip :) Will se if i'll need to go that way?
It not much room left so is going to be tight.. :p
Thanks :D
mYGeL
Cupra Widebody
got the front subframe in place yesterday. and also a Friend came over to help me to pair the propshaft togheter again, that was not a fun job and very greasy... haha
Here it will be welded the center bearing supports to the propshaft..
Before welding i sat inside with a bootle with water and fire extinghiser. :p
But all went well and One side welded..
Some zinc after that Primer. then i put body sealant över that araound them
today put suspension front and back refill all oils. Engine, antifreeze, gearbox, transferbox, Rear diff, Haldex and then brakefluid, adjust all wheel angles etc..
Also connect WG and maybe my Turbosmart Eboost2 Street.
Just need to find out where i can find connections i need.
That should be it for startupp and testrun.
Getting close. :D
mYGeL
Cupra Widebody
Well it is working now. :)
Only that we found at that the R32 Intank pump i bought togheter with the fueltank didnt work! completly dead :( So need to find a new one..
But started and tested with only the USP Motorsport fuelpump that worked. :)
Some pics..
Tight!
i sand blasted the crome intake and painted it black instead..
Time for startup...
Facebook video. For those who can se it?
https://www.facebook.com/photo.php?v=10150589499130168&set=vb.540330167&type=2&theater
<object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/10150589499130168" /><embed src="http://www.facebook.com/v/10150589499130168" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="224"></embed></object>
mYGeL
Cupra Widebody
Coming soon - Getaway in Stockholm part XXI haha You guys are all quite crazy behind the tidy streets and smart casual wardrobes :D
Sorry missed This.
haha time will tell..
Awesome, make sure you get a vid of the test drive up!!!!!!!!!
Sure will do :) Maybe tommorow. Ordered a new R32 Intank fuelpump today and should be here tommorow.. As soon as i have changed it. just sad i put 30 ltrs of fuel and will be a hell changing as the USP pump is strapped on the pump already. :p
Look forward to video of teh drive to
No problerm will come up in the next few days. :)
Need to Tig the rest of the rear exhaust and get the fuelpump changed.
This things a weapon awesome work mate attention to detail is out of this world [B)]:blink:
Thanks mate :) Doing my best modding the car to what i want. much work but thats the fun part of it. Mostly but not always.. :p
mYGeL
Cupra Widebody
Got the New R32 Fuelpump yesterday and fitted also :)
But it was a hell as the USP Pump was fitted and full tank with fuel in there so first we had to demount the USP pum before getting the broken R32 pump out.
And then mount the new one and get the USP pump back inthere. And it was hard even when fueltank was off the car and no fuel in there. And now first demount and then mount with full tank of fuel... xD
Exhaust also finally in place. :)
heres a video of startup with new exhaust..
http://www.youtube.com/watch?v=0T1VgjGBwXM
Getting close now :)
Maybe test drive on streets today??
