SAMS BLACK LCR GT2871 build. THE END :( !!!
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
thanks robbie, no i have not sorted it yet, but strangly i took it for a blast a few nights ago and all was well, or might have seemed that way as i havnt driven it for a week. something isnt right going by the logs so i will probably go up to bills pretty soon.
RS6
Nov 24, 2009
1,110
read this at work today looks amazing makes me want to get a set :D
trying to sort out wheel spacers for mine major £'ss! alas
sambryant
Mar 26, 2009
4,848
Bristol
small update on coilovers.
hello all, as i have now done over 150miles with with the coilovers and bushes fitted and tracking done, i can now confirm that i really love the new set up. corning at high speed is so sharp yet no body roll:thumbup:. ride comfort is so good, i can actually hit a pot hole and not break my back compared to the springs fitted before lol. i really am in love with how the car handles and recommend these ap coilovers to anyone.
also today i had a fault code come up, one i had before but many months ago,
16825 EVAP Emission Control Sys: Incorrect Flow
the n80 valve was renewed when i had this fault before, anyone else had this fault and how did you overcome it?
i think this may be the cause to some of my issues that i have had recently, well i hope so.
sam
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
sambryant
Mar 26, 2009
4,848
Bristol
hello all, another update.
tonight i decided to fit my 034 motorsports coil pack cover. if was easy to fit but did mean taking off the charge pipe and rear bracket. anyway heres a few pics.
first i removed the charge pipe and rear bracket, also i had to cut down the threads on the coil pack clamps as they were stuck up too high.
then i was a case of bolting down the cover and refitting the charge pipe ect.
pics of the finished result
before anyone says, i wil be having the blank plug on the charge pipe removed and welded over.
i will also get the rocker cover powdercoated in white but im not in to much of a rush for that atm.
overall im really happy with the cover and i like the fact that there pretty rare on here, so makes a nice change.
i do have one slight concern, as i have done the n249 bypass and all i have left is the sensor, i had to move it because it wouldnt fit under the coil pack cover, its now behind the charge pipe,zip tied to the bracket,
is this ok fitted here or should i move it due to heat from the turbo and manifold?
thanks all
comments welcome
LCR 225
Nick
May 1, 2010
323
Bristol
Looking good Sam well done. Not to sure about the n249, looks like it's going to get quite hot back there because of the heat from the turbo etc. I would just keep an eye on it if your going to keep it there. I'm guessing it's difficult to find a good home for it but if I were you I would try and move it, better safe than sorry :).
sambryant
Mar 26, 2009
4,848
Bristol
small update
hello all.
a good friend of mine (nick) gave me his audi tt strut brace on the weekend. he no longer wanted it for his lcr as he didnt fancy drilling his car (lcr).
so i start to trail fitting it, i needed to cut a little piece off to allow the brace to sit under the bonnet lifter.
now in place
now just sat in place
the brace will be powdercoated in white then i will fit it properly to the car :)
anyone know what nuts and bolts are best to use and of course look best, dont want them to rust lol. also any tips on fitting it, i know its easy to fit but some times tips are always good.
one other thing, what resistor do i need to completely remove the n249 valve? link?
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
6x m10x25mm
Jack the car up when tightening the nuts, the wheels will drop out the arches making it easier to get access. Apart from that looks like you've got it sorted mate.
Edit: Drill pilot holes first.
