hello all, another update.
tonight i decided to fit my 034 motorsports coil pack cover. if was easy to fit but did mean taking off the charge pipe and rear bracket. anyway heres a few pics.
first i removed the charge pipe and rear bracket, also i had to cut down the threads on the coil pack clamps as they were stuck up too high.
then i was a case of bolting down the cover and refitting the charge pipe ect.
pics of the finished result
before anyone says, i wil be having the blank plug on the charge pipe removed and welded over.
i will also get the rocker cover powdercoated in white but im not in to much of a rush for that atm.
overall im really happy with the cover and i like the fact that there pretty rare on here, so makes a nice change.
i do have one slight concern, as i have done the n249 bypass and all i have left is the sensor, i had to move it because it wouldnt fit under the coil pack cover, its now behind the charge pipe,zip tied to the bracket,
is this ok fitted here or should i move it due to heat from the turbo and manifold?
thanks all
comments welcome
