Status
Not open for further replies.
RobDon
Pro Detailer
IE rods and bearings have arrived - woohoo! :funk:
I have everything needed to do the bottom end now, so will get cracking on it next week. By the time I've put the new rods in I should have everything else I'm waiting on to finish off the head and get it all built back up again. :thumbup:
RobDon
Pro Detailer
Yeah, will get some this weekend.
Head is nearly finished and ready to be rebuilt, the new ferrous carbide cutter I got made short work of removing metal around the inlet ports. All the valve seats and chambers are all 100% clean now, all the ports have been smoothed out with the inlets left rougher than the exhaust. (I'll get pics of it this weekend) By the time i've lapped all the inlet valves in the new exhaust valves should be here, so I can then rebuild the head with new stem seals.
RobDon
Pro Detailer
Few pics:
IE 19mm rods with ARP bolts, assembly lube and OE rod bearings:
FlexHone tool for deglazing the bores:
Timing belt kit and new set of spark plugs:
I'll add some pics of the head later today or tomorrow. :)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Nice one Rob
Theres still a few of us wanting a RR session @ Wallace
If your up for it we have at least 10 cars wanting on so £35 again for the two runs
You could get the AVR set up at the same time
RobDon
Pro Detailer
OK here's some pics of the work I have done to the head, everything from just cleaning to smoothing and reprofiling the inlet entrances, removing steps in the casting, etc. etc. (the head is not fully clean yet, won't be until the valves have been lapped in, then it gets a final clean before re-assembly).
Removing nastly little steps in the inlets:
Best pic I think!
Exhaust ports have been cleaned and smoothed, will be polished more than this before reassembly:
Smooth transitions from the big port SEM into the head now:
Going to roughen up the inlet ports further still to promote atomisation:
Very close to the head being finished now, once the Supertech inconel exhaust valves arrive I can get them lapped in and the head back together.
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
ive done the same with my exhaust ports rob got them to a mirror smooth finish...Will be doing the inlet 2morro but i read that you roughen up the inlets to let fuel optismize... Not smooth them to a clear finish..
Looking awesome though
RobDon
Pro Detailer
Yeah, I've left my inlets rough.
Nothing much to report at the mo, started to clean up and lap the inlet valves into the head, once the new exhaust valves are here I can get the head built back up. Once the new piston rings are here I can get cracking on the rods too, so it will all happen at once!
Oh and I've decided to keep the baffled sump and fit it before trackdays next year.
RobDon
Pro Detailer
Here's 3 pics of the inlet valves that I have been cleaning up, pretty obvious which is before and after! Coarse abrasive buff for the underside to remove the carbon deposits and a carbon steel brush to clean up the topsides of the valves, both on the Dremel.
If you're ever doing stuff like this - make sure you wear gloves, eye protection and a dust mask. Little bits of carbon fly off all over the place and the valve itself gets hot, so be careful!
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Just wondering seeing the carbon build up on the valves.
Shell (Optimax and V Power) always quote there products as cleaning this/stopping this.
Would be interesting to see what colour these valves would be on a Shell petrol run car.
Mine has been 100% Optimax and now V Power but hopefully shouldn't see my valves for a while
RobDon
Pro Detailer
Remember my car had one previous owner for the first 2 years so he may have run supermarket junk fuel for 2 years before I got it.
The coating on the top came off easily compared to the carbon on the underside! Cylinder 4 was tough due to the oil burning. Thankfully I don't have to clean the exhaust valves as I have new ones to fit, just have to lap them into the head before fitting.
Status
