Status
Not open for further replies.
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
looking good rob, im sure you will of got the 16 rollers on the timing chain right.
them inlet collets are so bad need to glue them in, pita :D
v-g
is an alien.
Mar 10, 2004
938
Nowhere near, i.e. Norway.
Hi Rob,
Do you have any pics of your car on the compomotives?
Thanks,
Neil.
Maybe I can help.
RobDon
Pro Detailer
Thanks to my 'super fan'!
Nothing to report just now, kids are off on holiday this week so having to keep them entertained. I plan to do the rods next week, should only take a few days to swap the rods over then I can start building everything back up - hopefully all finished in about 3 weeks time.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Rob, we have a RR day on Sunday the 1st of November @ Wallace, I'm sure we can have a place for you and yours:)
RobDon
Pro Detailer
Thanks Willie but I'll most likely be still running the engine in, it will take me ages to do 1k miles before I can change the oil to synthetic and start giving it some.
I made a start on the bottom end today - drained the oil, removed the filter, disconnected the return line and level sensor and loosened off all the sump bolts.
I also removed the thermostat and replaced it with the lower temp Neuspeed one, so cooling kicks in earlier. I also got the matching fan switch as well.
http://www.awesome-gti.co.uk/product.php?xProd=5590&xSec=349
http://www.awesome-gti.co.uk/product.php?xProd=5587
RobDon
Pro Detailer
Some updates for you, got the sump off today, came off quite easily with no hassles:
The belly of the beast exposed:
Rods ready to come out now:
Old oil pump, all looks very clean inside the engine, no gunk or sludge:
Took the opportunity to spray some of the engine parts that looked pretty grubby, this is the lower timing belt cover and the accessory belt tensioner:
SO next week I'll have the rods and pistons out, hone the bores, fit the new rods and start getting it all back together again - shouldn't take long, the bottom end is quite simple to work on. :D
RobDon
Pro Detailer
Ok next update - rods and pistons are out and I have fitted the new IE rods. Just got to flexhone the bores and I am ready to rebuild the engine - woohoo!
Old rod removed from piston:
Came from cylinder #1:
New IE rod installed:
Doing them one at a time:
All done! I found this job very easy apart from getting the wrist pin c-clips back in!!!
I also invested in a set of ARP head studs and nuts, rather than use the OE stretch bolts, they are much stronger and have 40% better clamping force than the OE bolts.
I'll get the bores honed tomorrow and then the fun begins, rebuilding it all back up! :D
Status
