Requsted vs Actual Part II
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
4th gear on your six speed box, as flat a road as you can find.
Airflow looks healthy and it's boosting better in that last log that you've posted, it's making 1.4 bar against 1.2 requested.
I take it that's the new Revo code then? It's certainly less agressive...
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
well the guys at revo i.e Kev and Simon are being very helpful in getting to the bottom of this and the faulk code that i got could suggest that my FMIC is obviuosly more efficient than the standard ones but it could be that efficient that it has taken a fair chunk of the standard pressure drop, that the ECU is programed to deal with from standard, away. Thus meaning that the ECU no longer has to compensate for a pressure drop and this is what could be throwing up the faults and the problem in the first place.
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
yes the new revo code is both of the previous posts i have put up and i still think the car is adapting hence maybe why the boost is all over the place at the mo, i am still a novice at this stuff but learning all the time. Kev has asked me to log 114 and 115 tonight 4th gear 2000rpm to 6500/7000rpm to see if his theory about the FMIC is correct
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
Although i have no proof Pace did say that they struggled to measure a pressure drop across the system their instrumentsonly measured a 0.3 PSI drop in pressure
ryan_s3
1,270
It has been measured at 3-5psi but that was with alot more air being pushed through than a k04.
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
here are tonights logs 4th gear from 2000 rpm to 6500rpm to scared to go any further but this is also up hill as there not many staright flat roads around my area
'115
RPM Load Absolute Pres. Absolute Pres.
/min % mbar mbar
2120 59.4 1000 1190
2160 38.3 1000 1050
2160 17.3 1000 1020
2080 16.5 1000 1010
2000 50.4 1000 1000
2000 45.9 1000 1030
2000 48.1 1000 1040
2000 36.8 1000 1030
1960 34.6 1000 1020
1960 36.8 1000 1010
1920 43.6 1000 1020
1960 42.9 1000 1020
2000 51.1 1000 1030
2040 61.7 1000 1050
2080 34.6 1000 1040
2080 16.5 1000 1020
1960 13.5 1000 1010
1920 46.6 1000 1010
1920 50.4 1000 1040
1960 42.9 1000 1030
2000 44.4 1000 1030
2040 45.9 1000 1030
2080 38.3 1000 1030
2120 38.3 1000 1020
2160 35.3 1000 1020
2160 35.3 1000 1020
2200 52.6 1000 1020
2240 37.6 1000 1050
2200 15.8 1000 1020
2080 15 1000 1010
2040 35.3 1000 1000
2000 57.9 1000 1040
2000 54.1 1000 1060
2040 54.1 1000 1040
2040 66.2 1070 1050
2120 82 1160 1150
2280 129.3 2040 1430
2560 181.2 2100 2030
3040 191.7 2120 2540
3440 191.7 2160 2440
3800 191.7 2190 2410
4200 191.7 2170 2320
4440 191.7 2130 2180
4760 191 2050 2100
5000 186.5 2000 2030
5200 178.2 1960 1980
5440 178.9 1920 1990
5640 178.2 1870 1940
5840 168.4 1840 1940
6000 163.9 1830 1910
6120 165.4 1800 1920
6280 166.9 1770 1860
6200 16.5 1000 1860
5240 191.7 1970 2200
5400 191.7 1950 2120
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
'020
Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
CF CF CF CF
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
ok cheers ryan but before i do that i want ot find out why i am getting more boost than requested in quite a few places
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
I put my cleaned Green panel back in yesterday:
Code:
2240	11	100	1070	93.09	2440	57.61	98.8	16.5 B
2680	9	100	1810	94.71	3000	134.33	100	1.5 B
3400	9	87.8	2540	96.33	3760	152.72	100	6.0 B
4160	9	86.7	2510	97.94	4480	162.31	100	10.5 B
4800	12	96.5	2370	99.56	5160	180	100	11.3 B
5440	15	94.5	2220	101.17	5680	202.64	100	12.0 B
5920	18	95.7	2180	102.8	6160	191.86	98	15.0 B
6360	21	86.7	2080	104.42	6440	131.47	99.6	7.5 A
:D :thumbup:
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
The new N75 fixed the duty cycle problems, but I was still "only" getting 191-194 g/sec. I wonder if it was age or that split N75 hose that killed the N75...
The filter was really bogging (I'm sure it wasn't THAT long ago since I cleaned it). I managed a personal best of four fag ends this time :redface:
Thanks for your help John (you might stil get a full raft of logs to check though ;) )
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
Right guys just had an email from Kev letting me know what is possibly wrong with my car and basically to some it up i need a performance exhuast or someone has tampered with my Wastegate actuater think thats how its spelt.
I purchased the car from a police officer in Wales and he didnt do anything to the car and i know i havnt had any need to touch the wastegate, so i think that rules that out but i am getting it looked at anyway. Here is the email i got from Kev,
Hi Ben,
You’re basically overshooting requested boost and load.
Could be down to a couple of things which I’ll go through in a minute. First of all I’d turn down the boost levels (say to maybe 4 or 5) and up the timing (check VAG Com for CF when doing this) This should keep you away from any limits but also get some more power out of her.
I’d not reference the figures you saw on the dyno last month as you’d gone into limp mode on the way there so adaptation values would have been low… pulling settings back.
Looks as though your IC is very efficient although I can’t imagine it’s ‘that’ much more efficient than other ones we’ve seen out there. So problems could be arising from increased flow through the IC and a build up of back pressure with the stock exhaust system. Having said that the wastegate duty cycle looks very low for the requested figures… now this could be down to the hardware setup. But if you didn’t have the IC on I’d say it’s possible that someone’s been playing with the wastegate actuator (attached to the turbo, you’ll see a rod with a threaded end… it’d be the bolts on this that’d have been played with) could be causing the overboost.
It’s difficult to tell exactly what is causing it without checking it against other cars with similar spec/standard spec. We know that a standard spec LCR with software on doesn’t have these issues, we know it works on LCR’s with uprated IC’s, intakes, exhausts as well. So it’s either down to ‘a very efficient IC’ (which would be great although I’m not convinced at this point) in which case we could fettle the code to suit (although Stage 2 is really done for this) or a fettled wastegate actuator. You’d want to test/compare against a known good one.
It might be a benefit to run stage 2, but I’d really put that off until you’ve got the exhaust on. This isn’t necessarily going to fix your problems though if for example the wastegate has been played with. We wouldn’t know that without testing another car of the same spec that’s definitely not been altered.
Unfortunately without knowing the full extent of what’s happened in the past with the car and being able to test the IC/exhaust/etc. It’s very difficult to say. I hope this helps though.
Best Regards,
Kev Hall
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
sorry to drag ths post up from the past i found the reason for my high g/s and it was down to a perished hose that can be found at the top of the charge pipe very thin thing. Since i have fixed that my car doesnt go into limp mode and no fault codes, however recently been logging my car as i havnt done it since these last posts and my ECU is only requesting 1.1bar at the most and Kev at REVO has said i have the latest code on my car so why is this, i am running B6 T6 everything else seems fine except my airflow is only 176.3g/s which i am guessing is related to this as the higher that goes the more boost i should get right????????
