Hello Seatcupra.net
I have a 2008 Seat Leon 2,0 TFSI FR DSG, that's done 45.000 miles at the moment.
The problem is, that the car seems to make the required boost only above 3.000 RPM, where it pulls absolutely fine. Below 3.000 RPM I seem to get a lot of random misfires when accelerating at partial throttle. The car will buck and stutter like mad until I hit around 3.000 RPM after which, it will settle down and pull just fine.
When logging the car, I see that actual boost pretty far off from specified until the car hits around 2.800-3.000 RPM at which point the actual boost seems to catch up to specified. Fuel rail pressure is good and actual pressure keeps up with specified.
When running at WOT, I don't get as nearly many misfires, it's only really bad at partial throttle. Also, the problem seems to lessen a bit, once the engine is up to temp, however, if I idle for quite a few minutes and then pull away, it will buck again.
The car throws no fault codes.
The car is fitted with the following upgrades:
APR stage 2+ with RFD software
3" DP with 200 cell sportscat - stock catback
APR HPFP
Eurojet FMIC
BSH throttle body pipe
APR runner flap delete
Forge PCV fix and catch can kit
Within the last 1000 miles, the following things have been done in an attempt to resolve the issue:
New revision D original DV (switched from Forge FMFSITVR)
New cam follower
New N75 valve
New MAF sensor
New R8 coil packs
New NGK BKR8EIX sparkplugs - gapped to 0,028" as per APRs requirements
New coolant temperature sensors (both sensors changed)
Cleaned intake valves and removed carbon deposits
Oil change
DSG oil change
Have you got an idea?
As you can see, I've thrown pretty much every part (at least the one's I could think about) after the car at this point, and the problem persists.
I need someone to throw me a bone here - any ideas are very much appreciated!
Kindest regards
Bstones
APR HPFP
Eurojet FMIC
New cam follower
New N75 valve
New MAF sensor
New R8 coil packs
Oil change
DSG oil change
Kindest regards
Bstones
