Hi mate, quick question. Did you change any of the bushes when you got the ARB's fitted?
No mate, it'll be a job for the future. Cant image the standard ones being to bad though, the cars not even covered 30k yet!
Hi RDS,
The LG looks very OEM when in position. With regards to the few groves that you can see in the finish, these can sometimes be difficult to remove with affecting other areas of the pod, especially as it's a delicate piece. The obvious would to apply a further layer of filler to it and the gently sand it down to a flat finish, using a sanding block to avoid any uneven sanding marks. In the past, I've used a filler primer to finish the surface, with good results. It's effectively a thicker primer that cures just as well and helps even out those minor blemishes. It's available at Halfords; thought you might appreciate the advice.
I look forward to seeing pictures of it all finished.
James![]()
Looking good . great little home made pod . Can you make me one?
Looks good mate,but you need to get your cone more into the wing tho..
LQ looks tidy!
Fitted my HIDs today (H7 55w Pro Max 6000k) I'm very impressed with the amount of light they give off.
Here it is a few hours after completing the job:
I was considering ordering new sidelight bulbs as they looked alot more blue then the HIDs like in the first picture, but having looked again I think they go well together!
I'm ordering a hid kit and been asked if my car needs warning cancellers??
Do i need these for my leon??
I couldnt tell you mate, these are the ones I bought.
No worries!!
Just ordered the kit you got lol
Hope you don't mind![]()
