Good luck with making the grille and i know what you mean about the front plate being a PITA to find somewhere to put it.
I'm just going to honeycombe the centre bit and cut the crash bar so its not visible
What cooler do you currently have??
Which cooler you going for mate?
Plate will look cool![]()
Bigger isn't always better![]()
yeah your right, its thing like pressure loss across the core that are also important, mainly caused by smaller inlets, the toyo cooler has no pressure loss and intake temps are amazing. over my apexi (same size as normal forge cooler) i gained 15 ftlb on a 15 degree warmer day with no other mods. also on a power run intake temps stay within 5 degrees of out side temps. impressive stuff on a stage 2 k04 that runs silly hot![]()
Rich,
I had that toyo cooler on my lcr before my big forge, nice bit of kit for the money, spend a little extra time making the piping well and it fit's almost as good as the "kits" offered by tuners.
Good work man.
Number plate placement will be key
Looking good mate
Out of interest, when you do this grill mod do you have to cut the original number plate mounting off the bumper or can you remove it somehow?
Love your progress Richard.
No you have to cut the bumper mount unfortunately.
