Since the audio system is going to need a lot of power it needs some special batteries
So I've got two Odyssey PC1700 batteries to go in the car. Now these batteries weigh 27Kg
EACH!!! so they're going to need a pretty substantial mount.
Started to cut out the metal work needed today. I've used 35mmx20mm steal box section for it so it'll be nice and solid.
Once the base metal was cut out it looks like this...
As a quick trial I tried the two main supports in the boot and put the two batteries in rough position
So now I need to borrow a welder to weld the frame together and then make the box to go round the batteries and something to hold them solid. The battery tray will be sealed to prevent any fumes from entering the cabin of the car if the batteries leak.
I've also got to figure out how the battery tray is going to be mounted in the car. It will either be welded into the boot or bolted through the floor. Not decided which yet.
