Well yesterday was a bit of a let down. Went out in the morning and got some Toyos fitted to the wheels. Matt came over when I got back and we set to work swapping the rear brake discs over so the wheels could be fit.
We got the car on stands and started on the passenger side. Figured out
how to get all the bits off and we decided to fit the coilovers at the same time.
Got the passenger side striped off, then worked out
how to get the bearings into the new discs as well. Then the problems started
Top bolts on the drivers side topmount wouldn't undo, so had to drill the top of that away throguh the bolt until it came off. Got that done, and the new struts both bolted in. We set them both at an aproximate level so they matched but wouldn't know how low it would be until we got it back on the ground.
So on with the brakes. Matt started work on the drivers side to get the caliper and carier bolts off while I started on the passenger side.
That's when the real trouble started. Only had a pair of pliers to wind the piston in and I slipped and caught the dust seal, so now that caliper needs refurbing
We managed to break 3 8mm alley keys trying to undo the carrier bolts and they're still stuck fast.
So I only have 1 of the wheels on, a knackered caliper, and a welded on carrier on the other side.
Looks damn good though with the TT's on. The drop is a bit too much, needs raising slightly I think but I'm liking the wheels on the Cordy
