As in people you have taken on and beaten, like the Indians used to do when they beat someone, they took their scalp.Scalps?
lol Well if the opportunity arises I am willing to take on a bigger beast.As in people you have taken on and beaten, like the Indians used to do when they beat someone, they took their scalp.
A bit extreme in this case but its a figure of speach![]()
Andrew, thats not a bad idea...my car recently had a disagreement with a speed hump so undertray is half hanging off. I could use a another daily driver lol!log books / pink slips is more friendly
if ur sure u aint walking home![]()
maz you can always borrow mine as yoyr daily driver ,, bring it back modded and a detail to finish off like![]()
That would unbalance the car with more pots on the back Dan.Yer sign in mate 305 rear 4 pot 363 fronts 6 pot
That would be an AWESOME set up but you would find alot of wheel lock up unless you were running road slicks.Sorry I wrote it a bit retarded , there 6pots on the front with a 363 mm disk and 4 pot 305 mm on the rear
My sidewall section that holds the tray is damaged also. Too many rolling roads and the speed hump yesterday didnt help. Got Slick coming round tonight with his racing jack and stands so I can have a look at try a DIY.mines in the same boat , no under tray , also lost the pass side tray bit that holds the undertray on , and the air duct thingy that was attached
need my brake disks n pads fitted asap and the door carrier to put back on
cant be bothered at the min , but shud as when it rains its to late to do it then![]()
Panzer plate is only 10KG Stan. Some other plates I have seen are like 20+ KG.Well Maz,
I've done 256mm rear brakes conversion and I think that's enough for our "powers". There are 3 cars which have the same calipers: Leon 1M Cupra R, Audi S3 8L and Skoda Octavia 1 RS the calipers from those cars fits p'n'p. If you got rear caliper from 4x4 then you will need custom spacer which is not esspecially good solution. Also pads and discs fits from those cars. I get mine pads and discs from Black Diamond and I'm happy with them. You aill need to chage those round "discs protectors" which are behind rear discs for a bigger ones. Small clever advise: you can put there front discs from Leon 1.6i 256x22mm they are the same but cheaper. And the "panzer plate" it's not very good idea either - it lower the car dramatically and it's heavy like hell. Just remove OEM covers and enjoy. Also engine cooling will be better but it will affect engine bay with a dust.
Best regards,
Stan
I havent had the time mate, literally rushed off my feet. Can you contact that guy also?Maz
Its all coming along nicely!!
My neglected Golf will be yours for a weekend and I hope it comes back as gleaming as yours but trust me..paintwork is bad!
will pop by one evening for that key - hopefully tonight!
Any joy with the 280mm spacer?
Stan you are right about the 256mm being more than enough for our power but we are men and we want bigger.. lol
on a serious note I think the 280mm rallye discs are the same price as the 256mms (iirc £51 each from the stealers)
