Platinum FR - wolf in sheeps clothing
bruceR
2,559
652
Monifieth, Dundee
As mines is a diesel the emissions don’t apply, only a spot test. As long as it looks like a cat is fitted then all good
rockson
57
Slovenia
Friendly laws you have. :coolthumb
In our country every MOT includes also emissions test . No way you can pass without a cat. :redcard:
kanyewest
549
168
NW
So noticed one of my sidelights was fuller than the other, turns out that 3 of the 9 smd LEDs were knacked.
Bought new set and fitted in 10mins
New lamps on left
With HIDs
if you can get HIDs in that car, you think i could fit HIDs into my mk4 ibiza?
kanyewest
549
168
NW
Yep, my son used to have Ibiza FR and we put a set in that
ooh i didnt think that was possible!
could you perhaps send me a link to the set you used? the ebay item number i found earlier in the thread is for the sidelights you replaced
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,241
1,096
Kent
There's decent money in these oem cats mate, I usually chop the pipe sections off and post them to a cat recycling company for at least £70 a time.
Sent from my SM-G960F using Tapatalk
Thai-wronghorse
Dec 3, 2015
2,241
1,096
Kent
Hmmm, might look at that but it’s heavy for posting!!
Postage is usually covered on top. Even so once you've chopped it short a courier shouldn't be any more than a tenner anyway.
bruceR
2,559
652
Monifieth, Dundee
Noticed an annoying rattle which I was afraid I knew was going to happen, the heat shield around the downpipe had 5 securing washers missing. Fortunately TPS have these in stock so bought 10 (£1.04 ea). Up on axle stand, secured heat shield with new washers
Went for a drive and no more rattles
bruceR
2,559
652
Monifieth, Dundee
The missus said the amber engine light came on the other day . Got home from work 2day so went out to see and yep it stays on, linked in my code reader and only one error code which points towards either a glow plug or the harness (P0684 / 17068 Glow Plug/Heater implausible signal).
Will have to check see if it’s a glow plug or the harness - all of which I replaced a couple or 3 years ago
bruceR
2,559
652
Monifieth, Dundee
So ordered 4 new glow plugs fro TPS and got round to changing them today. However when I re-scanned for faults I am now getting “P0684 Glow Plug Control Module (J271) Implausible Signal”………aghhhh
Anyone know where the the module is and if easy to replace??
bruceR
2,559
652
Monifieth, Dundee
Just an update, a couple of days running the new glow plugs the amber warning light has gone out and I’ve no codes
Ah well happy days
Reactions: Yellow fr
AndrewJB
Aug 16, 2007
11,209
485
Maranello
Still had EML light on after changing all glow plugs so decided to replace the harness (or Bridge, as it's called on official system)
Stripped her down to get into it - the harness is well taped in and runs under battery & air filter housing with the plug shown here at top of pic just under "white" tape:
Unfortunately I'd bought a new harness from TPS and it turned out to be the wrong one :banned::censored: mine has 4 wires and not the 2 wire harness I bought. So a trip back to TPS next day - in wife's car:whistle:
So I got new (correct) glow plug harness from TPS, £39:
Decided to wrap it in waterproof tape to make it more OEM:
All plugged in then I routed as original:
I ended up cutting out as much of the original loom as I could, it was well taped in so just left 2/3 in the tray!!!!!!!
Just managed to get everything back in as the rain came on in force :cry: so will scan 2moro to see if the fault has cleared :whistle:
A lot more successful that my glow plug change on my previous daily MK2 Golf TDI, changed plugs, 26 year old loom broke up, spliced a new one in and wouldn't start doh! broken some wires in the main engine loom when undoing it all.
Tempted to change the plugs in my Leon now but don't want the same to happen again haha.
bruceR
2,559
652
Monifieth, Dundee
Just make sure the engine is warm/hot and I would recommend spraying the glow plugs with release oil or WD40 the night before - I’ve just replaced mine again and came out a treat with the engine hot
AndrewJB
Aug 16, 2007
11,209
485
Maranello
Plugs came out fine on my old 1.9TDI (AHU MK3 mechanical pump not PD) it was the harness that disintegrated when I pulled it out.
bruceR
2,559
652
Monifieth, Dundee
So been waiting for a while for the right priced airbag to come along and after a wee bit haggling I managed to bag a new mk3 Leon airbag
Day of attack started by refreshing over a couple of threads in other forums:
https://forums.vwvortex.com/showthr...Mk5-r32-wheel-in-mk4-!#/topics/4885139?page=1
http://forums.tdiclub.com/showthread.php?t=399709
So with no excuse I got into it.
I had already bought a spare airbag loom from mk1 Leon so cut off the yellow airbag plug and soldered the ends
Next I cut off the crimps from ‘black & ‘brown’ wires and soldered the ends.
I removed the mk3 Leon airbag plug (you have to lift out the orange lock to then be able to pull out the yellow plug)
Removed the mk3 loom from airbag and cut off the main plug as this will not fit mk1
Soldered all the ends and began joining:
For the horn,
- old BLACK to new BLACK/WHITE
- old BROWN to new BROWNS x2
For the airbag,
- old BLUE to new GREY/BLUE
- old BROWN to new WHITE
Covered joints with heat shrink. Reattached black & brown cables to airbag.
Out at car, disconnected battery -ve and pulled steering wheel out and down as far as possible. Removed airbag as per video on YouTube. Re-centred wheel and removed retaining bolt with m12 twin spline tool and ratchet
Refitted new steering wheel, making sure the alignment marks were in line and tightened up bolt.
Connected yellow main plug into connector and put airbag into steering wheel but not fully in. Connected the battery-ve and tested the ignition from outside the car - all lights went off including the airbag light so turned ignition on fully and let car idle for 5 minutes while I tidied up. Tested the horn - OK .
Pushed the airbag into steering wheel and switched the ignition off-on-off to recheck.
Happy days
