As mines is a diesel the emissions don’t apply, only a spot test. As long as it looks like a cat is fitted then all good
Friendly laws you have.As mines is a diesel the emissions don’t apply, only a spot test. As long as it looks like a cat is fitted then all good
if you can get HIDs in that car, you think i could fit HIDs into my mk4 ibiza?So noticed one of my sidelights was fuller than the other, turns out that 3 of the 9 smd LEDs were knacked.
Bought new set and fitted in 10mins
New lamps on left
With HIDs
ooh i didnt think that was possible!
Postage is usually covered on top. Even so once you've chopped it short a courier shouldn't be any more than a tenner anyway.Hmmm, might look at that but it’s heavy for posting!!
Still had EML light on after changing all glow plugs so decided to replace the harness (or Bridge, as it's called on official system)
Stripped her down to get into it - the harness is well taped in and runs under battery & air filter housing with the plug shown here at top of pic just under "white" tape:
Unfortunately I'd bought a new harness from TPS and it turned out to be the wrong one mine has 4 wires and not the 2 wire harness I bought. So a trip back to TPS next day - in wife's car
So I got new (correct) glow plug harness from TPS, £39:
Decided to wrap it in waterproof tape to make it more OEM:
All plugged in then I routed as original:
I ended up cutting out as much of the original loom as I could, it was well taped in so just left 2/3 in the tray!!!!!!!
Just managed to get everything back in as the rain came on in force so will scan 2moro to see if the fault has cleared
