mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
deceided, why have one side pipe , i thought why not invent 2 chuffs , few pics of bits ive done so far ,
3inch v band buzzed on inside/outside
downpipe finaly done ,think my welding coming on too:rolleyes:
then got grinder out and choped pipe to make a v pipe for the twin pipes:D
powernut
475
looks sweet as mate
in that case few more for you lol , thought idmake/ buzz up a quick intake
well decided to make a little start on a homemade short runner as im having heat soak issiues in high boost, problem is in a mk1 room is tight , ie front rad/fans/rear 6speed gearbox and transforbox near steering rack so unsure how it may turn out , first old engine picture
decided to polish rocker cover
welded some alloy tubes on
not over happy but fits and works ,just wish i had more room to make a clyinder type
powernut
475
I hope so,its awesome!
cheers let me tell you something that dam downpipe was a chuffing nightmare as trying to get a 3inch pipe bent around to miss servo then undermanifold misinf 6speed gearbox the making room between transforbox.drive/steering rack ,then out between prop and chassi , very limited in a mk1 :D
powernut
475
the weld look great mate, never tried using a tig only ever used a mig
i just buy the lot and hit the trigger and away you go , tigs a bit like gas welding but easyer ,,migs fastist , stick great just watch for ramdom flashers lol
Apr 23, 2010
914
Here
Had some good arc eye from aluminium welding :blink: Forgot the number of times I've sat up in the middle of the night with cold wet tissue over my eyes lol.
shaun.
converted
Mar 26, 2010
457
leicester
i know that feeling i spent ages welding a LDV van once and got arch eye really bad its horrible
powernut
475
cheers guys always nice to have a decent relpy........ not mutch to add , got a quick pic to add in a bit , then i need to make some side pipes , id like straight thew but they would be so chuffing noisey, also another plan , im thinking doing away with 4wd , and fit a lsd instead , but carnt think whats best to do 2wd lsd 4wd no lsd ?
powernut
475
i have just spent the last 4days working my way through this thread
O M F G !!!!!!!
what gave you the idea to start the build in the 1st place???
i think its awesome
well basicly started as a bit of fun , from a old 1.6 4speed oil burner , i thought id just add a vr , then thing progressed to 6speed , turbos , then couldnt get tracksion so , thought id thow a electric 2/4wd system , helped loads, with steering been heavy just modifed a caddy van dash, fitted vr6 clocked rewired a few bits , and carried on from there really ,, missed one lol
