mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
cheers ben manifolds fine ,just seller didnt meation there on t25 turbo flanges lol ,, i thought chuff ill mod it ,now bang on ,,, i just hope the turbo clears ,firewall and intake fits ,as this was guess work tbh ,,
Sep 23, 2009
534
Bedfordshire
This mate, is amazing, I haven't posted on your thread in a while but i still get the emails come through on the Blackberry :) ! Keep up the good work buddy!
jamandspoon81
239
I love the good old British build it in your shed factor to this.it's the sort of thing that made Britain great.what a beast!
powernut
475
lol thanks , well if you dont have a go , u,ll never know...what may end up coming out of ur garages :lol:
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
wow what a read. just read from page 1 to 41. this has to be some of the best work i have seen, well done powernut :)
powernut
475
well not really mutch to add guys , ive not fitted the r32 as yet ,reason is , i exspected my vr6t to pop first , but im wrong , hoping to get a few little videos up ,pulling 20/30psi on 95ron , only thing is im breaking stock driveshafts pmsl ,,mosty rear ones... dose anyone here know the driveshaft spline info and size , as i need to find some off a differnert car? as 2wd is no fun , just loads of torque steer and wheel spin,,,,
quick pic
4plie hoses arnt lasting long were can i get stronger ones from
Mar 20, 2009
1,707
Largs Scotland
Hows things going with this mate?
Any manifolds left over from the 12V VR6 im converting my mk2 golf to a VR6 shortly and i do miss the sound of a turbo :whistle:
powernut
475
what manifold ru after?
ive decided as the therad started a 24v ,thought might as well add a mk5 r32 turbo :)
more home diy
grrr didnt relise mk5 r32 clutch carnt be used on a 2.8 4motion solid flywheel , (differncernt depths)
trail fitted
few sensors added , my save a few lights flashing on the dash
made as mutch free..ish room i could in the space i have left
then hit a issiuse exhust carnt go under car, and trying to fit a large hx40 turbo on this manifold was a tw..t , but bit of modifying turbos fitted and made a new exhuast pipe
powernut
475
finshed exhuast , just need wrapping
tig welding coming on i reckon...
fits good
next made some custom alloy tubing and buzzed them up
up to date , intercooler to finish off then start on the wireing to get the buggar runing
.ps bit of advise how mutch boost will a 38mm hold on a r32 before boost creep?
andany one have a ekta water piping daigram ,plus a 96 mk3 vr6 obd2 8pin wireing , as my other laptps gone down
Mar 20, 2009
1,707
Largs Scotland
Alrite mate not sure if you still come on here but i was looking for some guidance on timing chains. I have a 92 vr6 with the dual upper chain and when i try to tighten the tensioner bolt in it only goes so far then just stops but its not hitting anything, was just wondering if you have ever had any issues like that? Its the new style tensioner bolt aswell.
powernut
475
hi pal , right make sure no1 pistion is tdc, and crank wheel is algined with both caseing and pulley marks (around 5 o clock) both camshafts are locked ,then re lease the oil from tensionor (thrers 2 types one with a tiny hole in centre .bit of 0/6 mig wire to realse it , then re prime in new oil ,to get the right tension , put a long bolt in an measure frrom were the chain tensionor to the outer thread were thread ends, (then you have the approx lengh so u dont risk over tighterning.(usely on obd1 twin cams , on obd2 ive found some ofthese have double changes and have a black plastic chain tensionor ,but the adjustable tensionor has a flat surface with no hole in the end , ive found these to be crap and can stick when refitting. make sure the chain tensionor is free moving and you dont have any chain slack ,as sometimes u can be half a tooth out ;)
