K04 MK3 Ibiza Cupra Track Ready - RIP
MattJAbela
207
Medway
I was only going 1.9 with some 83mm pistons but this 2.0TSFI crank out of a 2012 S3 came up from a mate that i couldnt refuse haha. Havent deicded on engine spec 100% tbh once my Ring trip and my holiday is out the way ill set my wish list in stone.
What you planning? I brought and a spare engine rather than taking mine off the road so i didnt get bored and break the car half way through the build.
Yeah i'm still undecided on the total plans of what im going to do. I doubt the car will get garaged but an engine will be built for it. Not sure on specs or anything yet as its a while away.
Does the S3 crank fit then? Whats the benefits?
ian_jobson
272
Medway towns, Kent
Just finished reading your thread mate, top work! defo have the same attitude to it as me in that everything must be clean and no expenses spared!
Will likely pick your brains on a few bits
Whip the sump and head off tonight
Started by turning the block upside down to drain some oil
Sump off and started striping the pick up off
Back up the right way spilling more oil and coolant
Plugs out
Seem to of served Berg well
Head bolts out with old wheel dealer carboard trick haha
Head off
The oil pump, is it a case of undoing the 10mm bolts holding it down and wiggling it off the chain?
Checked over head tonight and all seemed good
Will clean up nicely i reckon
Head gasket seem ok too
Put me head stands together and drop the head on
Need to decide on Large Port Head or porting the Small port?? Ideas anyone?
Removed the oil pump next
All good
Next dropped the rods and pistons out.
Next is to take the crank out and oil squirters out then strip down to just a bare block.
