iTB Ibiza Cupra 16v Track Toy - Engine Rebuild, Aero & More Page 73+
benoit62
15
hi dave
you to weigh the difference between the bonnet oem, and the bonnet fiber?
I'll get mine on this weekend at ron!
I weigh my seat when I was buying (equipped race rally), it weighed 2155lbs ... yours should be much more slight!
I would be curious to know the actual weight!
you to find or suspension wishbones? it is beautifully realized!
you did not think to make a mecano welded?
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Ron told me the bonnet is 2kgs, I had a mate weigh a OEM bonnet & it was 12kgs so should be a 10kg saving.
The wishbones aren't fitted yet but hopefully I will be starting them this weekend when I get my car back
Dave_R
Sep 20, 2004
3,666
South Wales
Went up to OSE this afternoon to see Mark from Earl's doing my hardlines, very happy with the work but means I need to polish them up to get them shiney.... Few hours of buffing for me with the weekends :)
First a photo of the seat mounts
Pipe work going to my brake lever
Going through the car
And then where they will be going down to the rear calipers
Not 100% finished yet he needs to make up the braided hoses from the rear to the calipers & supply the bulk head fittings, also I'm having braided hose straight from the master cylinder to the front brakes.
Went looking for my bonnet & found it on to of a Mk1 Escort :D
Had a little noise around his workshop, didn't take any pics but will next time, he's building a Mk1 Transit with a 55 plate chassis underneath that he's building for a Ford Dealer down in Somerset and also he's building a S2000 BUT with a shell of a Mk1 Escort Estate with forestry aches!
So I've not found my ideal Van, stuff a T5 lol
Dave_R
Sep 20, 2004
3,666
South Wales
Well Thursday I collected my car from Old School Engineering, few pics of the car outside waiting for me
The new towing eye
And a few of you eagle eye'd readers may have noticed my mud flaps have gone
Loaded up ready to go home
Got home, went to reverse the car off the trailer and heard a "crack" got out and did this
What happened was when I went to collect the car, I had noticed the drivers side tyre was looking flat but got on the triller fine. Rolled the car back & fore and cleared the wheel choke on the trailer, when I went to get the car off the trailer it hit the wheel choke cracking the front splitter. The wheel strap must have left some air out of the tyre I guess, so will be checking the wheel over soon.
Dropped the splitter back up to OSE the next day to get repaired, was gutted but found it funny that all the times I have come off a track I never marked the body work and then reversing off the trailer I do this lol.
Put the car back in the garage and finally get to see the car in there with my new flag
And had a go of removing the bonnet
Spent the whole day clay baring, polishing & waxing the car, also started to polish up my brake pipes inside the car. Got a load of jobs I want to do to the car over the next few weeks,
Fit the solid lower arms
Powder coat the uprights
Fit new wheel bearings
Get some uprated spring rated springs (340lbs F&R at the moment and do away with the helper spring)
Get my rad fixed
Sort a template to get the carbon fibre boot panel done
Fit a isolation switch
Need heat sleeves to cover the braided hoses on the front (they near the manifold)
Remove the ABS sensors & wires
Looking into some solid front top mounts
Got a few things to do and I'm in two minds to go for the solid lifters and then car run 290-300 cams mmmmmmmmm.
keefr22
I just joined the forum today & I'm glad to see you're still developing your car - my son first pointed your thread out to me a few years back when he still had a Mk2 Cupra. He's moved on to a historic rally Mini Clubman (half shares with me!) but I couldn't bear to see the Ibiza go so bought it off him! I'd really like to get it half as good as yours one day...!! :)
keef
Dave_R
Sep 20, 2004
3,666
South Wales
Thanks keef!!
The car has come a long way over the past few years... Still got a few things to come to :)
Dave_R
Sep 20, 2004
3,666
South Wales
Since I had my car back from OSE, I removed the seats to give more room & polished up the brake lines.
The line at top I polished and the two after the splitter hasn't been done.
Removed the rad, to get it back up to AH Fabrication to get repaired
Up on the axle stands to get to work on my suspension overhaul
I'm going to be fitting the rose jointed lower arms from Saxon Motorsport and I'm in talks with Dave Spires about uprated springs and reworking my dampers to suit (thanks to NigeP for pointed me in his direction).
Lower arm & upright off
Hubs removed
Uprights are getting powder coating in black & the strut brace is going red
Coilovers are off and ready to get the word from Dave Spires to book the dampers into Bilstein UK for a rebuild with stiffer dampers.
The rear beam removed was going to powder coat this but because I have had the stub axle shimmed for camber & toe I don't want to remove them so will be painting this myself.
And a few photos of some empty aches
I got new ball joints & wheel bearings ready to be fitted and also noticed a split in the gaitor for the track rod end so I've ordered a new set. I'm still waiting on these rose joint rear beam bushes but may get the black Powerflex race bushes for now.
I have also purchased some solid front top mounts from Comp Brake but they do not fit, currently passing emails back and fore but if anyone knows of somewhere else then please let me know. The Mk2 Ibiza uses the same front top mounts as Mk3 Golf.
Also I have some bug pack rear top mounts that I had but never fitted when I first fitted my coilovers so may fit them BUT I am on the look out for solid or race spec mounts so if any of you know where I can get them from please share. They are the same mounts that are used on the Mk2 Golf.
Dave have you decided on what set up your going for spring/shock wise? And are your front shocks rebound adjustable?
Looking at buying compbrake top mounts for my mk3 but have a funny feeling there not going to fit either after reading a few threads.
Dave_R
Sep 20, 2004
3,666
South Wales
I had that feeling to, even asked if they 100% fit!
Bilstein are going to just beef up the dampers to suit the spring choice, I'm looking at 900lbs on the front & 550lbs on the rear. So quite a lot really :)
Dave_R
Sep 20, 2004
3,666
South Wales
Done a few more jobs, cleaned the inside of the car & my seats
During
Clean (left) vs Dirty (right)
And the interior back together
Sorted the cables out on my battery, now running 50mm cables from battery to starter & then 25mm from starter to alternator.
Painted my rear beam
Dropped the uprights & strut brace up to PPS Powder Coatings & my radiator up to AH Fabrications this afternoon, should hopefully have them back at the end of the week and I'm going to be ordering some Powerflex Black series rear beam bushes tomorrow & run them until the rose joint ones are made up.
benoit62
15
you did not think to do with turrets to avoid drafts changes in camber angles supports?
and you can also put more camber shims in amount, it is better!
watching: w. pieces-auto-competition.com/product.php?id_product=41 (renault model supports)
my step-brother makes its golf 3 track day, it's just a regale!!
I will soon do on mine!!!!
Dave_R
Sep 20, 2004
3,666
South Wales
Thanks guys!!
Ordered these yesterday
D2 Racing Solid Top Mounts with camber adjustment, also ordered a set of Powerflex Black Series rear beam bushes to use until I get hold of the rose joint ones.
Dave_R
Sep 20, 2004
3,666
South Wales
Few little updates, I missed the post man yesterday so I got to wait till tomorrow to collect my rear beam bushes so went ahead with making my bush removal tool & took the bushes out ready.
And out comes the bush
Save spending £30 on something that can easily be made!
Tomorrow I'm going to pop down to Gripz (my mates garage) to use his press & fit the wheel bearings to the uprights I just had powder coated.
Went to fit the solid lower arms this afternoon but found a part of the sub frame that needs to be grinded slightly to give more room for movement but its too thick to file down & I don't have a grinder or grinding disc so a trip to B&Q tomorrow.
Had plans to do a bit today but woke up late off nights & missed the post, etc... One of them days when nothing falls right!
Dave_R
Sep 20, 2004
3,666
South Wales
They lookuch better than the compbrake ones
Got to mod my compbrake ones to fit after asking if they will fit with out modding them or the car :doh:
The ones I had from them had no chance in fitting, unless I put them on a lathe and cut about 20mm off so stuff that.
