Robbie C's Ibiza Cupra
Dale!
Robbie C's Personal Techy
Jan 11, 2011
193
Swindon
Little more info from mine and Rob's trip..
So the idea was to go for a good blast with a couple of cars.... note the "idea"
Total trip ended up with 14 hours driving covering 700miles is on friday night/sat morning!
Roads included:
- Black Mountain Pass
- Llanberis Pass
- Two sides of the Evo Triangle
- Snake pass
- Oopnurthring in the Peak District
- Fosse way back to home
The Route:
Here are couple pictures, only ones from in daylight mainly
Getting ready to start 10pm from Swindon
Good temperature for a drive, getting on well just after 1am
Pit stop for fuel, could only find a Tescos :( momentum it was then..
Carrying on into the night...
Then it was on to aberystwyth pier
No dog ****....
Getting late now
More Fuel good V power this time :)
On to the peak district and now it was getting light some pictures were taken :)
Here are 2 little clips, nothing great due to the low temps and risk of ice..
VXR Driving in Wales - YouTube
VXR Black Mountain Pass - YouTube
Overall great trip, plan is to do another next year as this was a tester :)
Jan 8, 2007
2,958
Wiltshire
It's that time of year again where Pedro comes out from under his sheet and out of hibernation.
I was amazed/mildly impressed to find that after checking all fluids and reconnecting the battery he fired straight back into life, before I took it out to get everything up to temperature and blow the cob webs off.
Tonight I went out with a friend to collect a few logs after I noticed a drop in boost; I'm certain last year I was peaking at 24-26 PSI, vs what looks more like 20-21 PSI now. On WOT I can hear and see the boost fluctuating between 20-22 PSI, but seemingly throttled by something.
Bearing in mind it's also a cold night (sub 3 Deg C) the CFs concern me.
All logs were collected starting in 4th, applying WOT from 2,000 - 6,000 RPM:
Fault codes were cleared before these runs, and a subsequent scan showed:
Code:
Control Module Part Number: 6K0 906 032 AA
  Component and/or Version: 1.8L 20VT EU3    01 0002
           Software Coding: 10500
            Work Shop Code: WSC 12849
3 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
        P1116 - 35-00 - -
16885 - Vehicle Speed Sensor: Implausible Signal
        P0501 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
        P0134 - 35-00 - -
Lambda is "expected", I've had problems with this for quite a while...
Notice that requested boost only equates to around 21 PSI which is what I see, though looking back over my latest dyno plots and from memory of last year's track day I'm certain I was peaking at 24-26 PSI.
Anything further I should look at from these initial logs?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
lol...........
REMEMBER it can only view and request 2550....... 22.5psi.......... So logging something which can only show these figures....
The turbo was clearly Tired last here.. Smoking..
I would'nt be surprised if its not tired now.. Track days and being run flat out etc...
Welcome to pop along for free check on the dyno, but it was showing signs of being tired (turbo) previously. Need a nice new spec hybrid of Dans making..
Lupo 300bhp off 16psi boost :)
Also.. just relooked at the above logs.. Fuel Injector max IDC is >100% after 5500rpm....... Run out of injectors.
2,958
Wiltshire
Thanks, I'll give you a shout when I'm back home and free to head over.
The IDCs were noted when it was last mapped.
Is there any link with the likely tired tubby and increased CFs?
If its logging these numbers in 3 Deg ambient temps it concerns me what it'll do on a summers day
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
check your pipes for oil on the throttle body...
joehirth
Rate me up baby
Apr 19, 2010
1,896
Woking, Surrey
www.facebook.com
I've had a little oil in my cold side piping since fitting GT30, how much would you say is for concern?
Also with regards to the mapping why are the injectors maxed out at 5.5k and then continued all the way to redline?! Surely you would pull boost/ add timing to ensure safety and prevent potential detonation. Can you get a log for timing?
Keen to find out more about this.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
so long as afr's are being maintained its an observation I made at the time.
Robbie wanted it max'd out... and aggresive.. which is what he got given.
The turbo is undersized for the 1900cc it is now imho, and also tired. Its had a hard little life and is a few years old now.
CF can pull12's, 6 of which have been consumed already.
WMI check also.... is it actually pumping/atomising?
wideband for the win.
some small oil misting is fairly normal, but when its running out of the throttle body and pipes like I see frequently, this explains the high CF's are its oil breathing is derating any effective knock resistance from the fuel... Not saying thats whats occuring here, but its a check to make to be sure.
Jan 8, 2007
2,958
Wiltshire
I'll have a word with Dale to remove the TIP and see if there's any signs of wear/play in the compressor as well as check my intake pipes for oil.
I wouldn't expect the car to pull any CFs on a ~3 Deg cold night, that's what surprised me. My AEM LED suggests the WMI is working fine.
I'm completely at a crossroads as to what to do with this car now; either invest in a 2868 HTA setup with different management to overcome the stalling and give me more control on monitoring what's going on, stripped with buckets and harnesses....or go for the S2 Exige S
Dale!
Jan 11, 2011
193
Swindon
Sorry Dale's not here.... Please leave a message!!!
Time big turbo and management :)
Exige is gay.... Just like you!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
you trust an led?
remove nozzle, press TEST and see what actually Sprays is an actual test
Wideband conversion for the win too :p
IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
I'm doing a full LCR ecu and loom conversion on an Ibiza in the next month or so. Full wideband and EGT with VVT too. Will prob be a pain to do though. We shall see.
If the AEM has been stood then check the filter and nozzle. These gunk up.
