Well Thursday I collected my car from Old School Engineering, few pics of the car outside waiting for me
The new towing eye
And a few of you eagle eye'd readers may have noticed my mud flaps have gone
Loaded up ready to go home
Got home, went to reverse the car off the trailer and heard a "crack" got out and did this
What happened was when I went to collect the car, I had noticed the drivers side tyre was looking flat but got on the triller fine. Rolled the car back & fore and cleared the wheel choke on the trailer, when I went to get the car off the trailer it hit the wheel choke cracking the front splitter. The wheel strap must have left some air out of the tyre I guess, so will be checking the wheel over soon.
Dropped the splitter back up to OSE the next day to get repaired, was gutted but found it funny that all the times I have come off a track I never marked the body work and then reversing off the trailer I do this lol.
Put the car back in the garage and finally get to see the car in there with my new flag
And had a go of removing the bonnet
Spent the whole day clay baring, polishing & waxing the car, also started to polish up my brake pipes inside the car. Got a load of jobs I want to do to the car over the next few weeks,
Fit the solid lower arms
Powder coat the uprights
Fit new wheel bearings
Get some uprated spring rated springs (340lbs F&R at the moment and do away with the helper spring)
Get my rad fixed
Sort a template to get the carbon fibre boot panel done
Fit a isolation switch
Need heat sleeves to cover the braided hoses on the front (they near the manifold)
Remove the ABS sensors & wires
Looking into some solid front top mounts
Got a few things to do and I'm in two minds to go for the solid lifters and then car run
290-300 cams mmmmmmmmm.
