And not having one induces huge uncontrollable bouts of jealously
I think this is true
Turning on the rear windscreen heater also turns on the heated wing mirrors.
m.r.davies said:You can get weird boot things (genunie seat)
auto lights - its the future...
It also has a slot in the lower dash under the steering wheel for the service book which no one uses.
They have heated mirrors...![]()
At first I refused to post in this thread - first it's LCR centric (you bloody snobs) and second it states the blooming obvious, I mean, do you lot not read the manual?:tut:
I was going to post that all LCRs have a wheel at each corner.
But, then I remembered -
If you do a ECU reset by disconnecting the battery a lot - you can disable the need to enter the code when the radio powers back up (it's in the manual).
Check you have a pair of tongs in the boot for removing the wheel nut covers. Look closely, they're black and about three inches long. In fact, you should have a full sized spare in an LCR, but a few "came from the factory" (yeah, right) with a steel spare - I don't think this will fit over the brembos...
also if you forgot to take the hand brake off and drive away a beeping sound (like the low fuel beep) will come on... try it!
And, it seems, forces you to attach a ridiculous body kit to your car in the vain hope it will look like one![]()
Like the need for 3rd gear to get a true 0-60mph. Do all LC's come with climate control allowing display change? Not sure, does the LC have the alarm button down by drivers seat?
one i found the other day on a track day, over about 110mph the drivers window will not close as the pressure inside must be too great so it just automatically goes right down again.
