Interesting LCR facts....
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
you can tell when your remote key fob battery is dying as the range dramtically decreases
......mine pretty poor actually, i have to be a few meters away before it works
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
At first I refused to post in this thread - first it's LCR centric (you bloody snobs) and second it states the blooming obvious, I mean, do you lot not read the manual? :rolleyes: :tut:
I was going to post that all LCRs have a wheel at each corner.
But, then I remembered -
If you do a ECU reset by disconnecting the battery a lot - you can disable the need to enter the code when the radio powers back up (it's in the manual).
Check you have a pair of tongs in the boot for removing the wheel nut covers. Look closely, they're black and about three inches long. In fact, you should have a full sized spare in an LCR, but a few "came from the factory" (yeah, right) with a steel spare - I don't think this will fit over the brembos...
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Some LCR's had a vanity mirror with illumination some didn't
Some LCR's had a CD Changer as standard some didn't
Some 210LCR's had square mirrors (up to circa October 2003 e.g. 03/52 plate) after this date they were tear drop shaped
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
also if you forgot to take the hand brake off and drive away a beeping sound (like the low fuel beep) will come on :yes:... try it! ;)
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
So it's safe to say that if you leave your handbrake on while driving to the petrol station to fill your empty tank, whilst having no washer fluid, you're about to go deaf! ;)
Mitchy
TTRS
Oct 12, 2004
2,310
Not so much LCR centric mate but opening post was made from observations on my LCR, not sure if they are the same in LC.
Like the need for 3rd gear to get a true 0-60mph. Do all LC's come with climate control allowing display change? Not sure, does the LC have the alarm button down by drivers seat?
Im sure i read the manual aswell, must have missed all these:rolleyes:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
And, it seems, forces you to attach a ridiculous body kit to your car in the vain hope it will look like one :hide:
:lol: No, it's not supposed to be an LCR lookalike - that was the dealer bodykit option at new.
Yes to both. (the alarm button is close to the LC electric seat controls ;) )
Cupra_power
torque ain't cheap
Nov 1, 2004
517
the burbs...
one i found the other day on a track day, over about 110mph the drivers window will not close as the pressure inside must be too great so it just automatically goes right down again.
That is probably the safety feature which stops the window clsosing if it senses resistance. It happened on both the LC and LCR. If you are clsoing the window and go over a sharp bump the window will automatically wind down, also turning off the one touch close function until the car has been restarted.
