Weekend has arrived so time to do some work on my car
Got the new actuator sent to me from CR Turbo.
Was just going to swap it over but Dan (beachbuggy on Audi-Sport) told me to fit a spacer between the actuator and the bracket as the reason it failed was the rod is at an angle, it needed to be straight out at 90 degrees.
He fitted a spacer to Prawns actuator:
So i did the same on mine - just used a washer to get it positioned in roughly the same position as in the pic.
Getting to the actuator is a bit tricky - removed the TIP, chargepipe and heatshield. Its a bit fiddly but not as hard as last weeks job (clutch)..
Happy to report that the new actuator is fitted and the car no longer overboosts
Running at actuator pressure until I sort out the WMI (next weeks job) and I set up the tension spot on so its boosts to 12PSI and no more.
However as this car hates me with a passion - I did come across something which has ruined my day:
Cracked manifold
For the past two or so weeks the car has made a noise as if the exhaust was blowing - certainly more noticeable since the SMF was removed.
Now I put this down to my decat pipe. It was a bit of a bodge job and I used cheapo ebay gaskets - which I noticed were blowing a few weeks after the remap.
I took them off and used just exhaust paste. That didn't last long either (unsurprisingly) so it is blowing again. I have ordered some decent quality gaskets and they will be fitted next weekend.
I never expected the manifold to be cracked. It is a V2 which has had extra welds done to it, and I am running with the support bracket on the turbo.
So what next?
After all the problems I have had most people would have given up by now. But i'm not going to!
I could make loads breaking it - but then what car would I buy next? Something else that I would end up modifying and spending even more money on!
The car has had far too much time and money spent on it to give up now.
So plan is to sort out the final few remaining issues (wheel alignment and re fitting the WMI) and not touch the manifold until the summer...
I just can't be bothered to do it now. I will have to remove the head - I struggled loads fitting the manifold when it was on the engine stand so there is no way I can swap it over when its on the car!
Also will get the turbo checked over by beachbuggy. He found a few issues with Prawns turbo - mainly it had the wrong thrust collar fitted and would have failed if left as it was.
So there we have it - just when you thought it couldn't get any worse - it does
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
